Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 8 Guests are viewing this topic.
Evening, about D-CAAY:
I did the investigation on-board train on a small Netbook. That's why I haven't noticed that google has changed the search request from D-CAAY to D-CAAE as no results were found about D-CAAY. Therefore, my information was about D-CAAE and not about D-CAAY. In the meantime D-CAAY  will remain unknown, as I wasn't able to find anything about it. Sorry for posting this bug. Well, four eyes are better than two...
No problems Ingo, thanks anyway.
flygfantast
Alan,
Another Estonian not populating: 511094 (no callsign, tracked twice today)
Niklas
Cable: Ecoflex-10 (10m+1m)
Nothing on it yet Niklas.
chewycanes
#1580
Evening Alan
A46E8D N385HA A332 Hawaian Airlines (from GA and detected by Modes Forum) Bit out of his way so i guess might be changing hands ?
505D85 OM-GLE PRM1 ex G-ORXI arrived biggin Hill from Modes Forum and GA.
484F7D PH-EZU & 484F7C PH-EZT E190'S on delivery from KLM to AMS. From GA and Modes forum.
Brian
Hi Brian,
The are all in the d/b.
The Hawaiian, Airbus A330-243 c/n 1295 was on delivery
PH-EZT c/n 19000519 and PH-EZU c/n 19000522
YXUphoto
4B1E1B
4CA4B1
A51D6A
ADFEF4
C005DD
Some unresolved codes.  Last one comes up as C-FCFS (SR20)
Morning,
489C02 SP-HAC has populated with following details: AT: A320, AN: A320- AC: none, CN: none could you confirm,. that it is in the db with full detail of A320-233 Small Planet Airlines 739?
Errata:
3E3865 D-IMOB has populated with false registration D-IOMB
flygfantast
Alan,
511098 ES-AEB populated incorrectly as ES-EAB.
Niklas
Hi Ingo,
SP-HAC in the d/b as follows
489C02, SP-AHC, Airbus A320-233, c/n, 739, Small Planet Airlines Polska
Amended D-IMOB
Mark,
4B1E1B decodes to HB-LKL which is not assigned.  Previous holder of the registration is now C-GEON, Piper PA-27-250 Aztec F, c/n 27-7754153
4CA4B1 unknown
A51D6A decodes to N429DS not assigned by FAA.  Only previous holder of the registration I can find is now D-ENWR DA40
ADFEF4 does not decode
C005DD C-FCFS, Cirrus SR20, c/n 585, David Codack
flygfantast
Alan,
SE-JPB is miscoding it's old hex 405196 (and using callsign GKATG).
SE-JPB Bell 206L-1 LongRanger, c/n 45783, Arctic Air
Mil:
3E8CA7 GAF962
3E9524 GAF022
Niklas
