Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 27 Guests are viewing this topic.
Clive
AvDb and GAS both have 0640E9 as 5N-NOC an HA4T c/n RC-38 and thats whats in the Airnav d/b.  If you can positively identify 0640E9 against a B190 I will update the database, AvDb and GAS
405CC5 decodes to G-CFHA with Bristows UK and was exported to Nigeria with Bristows Nigeria as 5N-BLX S-92A c/n 920082
superspotter
Cheers Alan. It's not possible for me to id it positively however, too much of a coincidence for my liking when both times I have seen a Beech 1900 land which corresponds with what I am seeing on the screen. Lagos is not very busy at all, it's not a Heathrow! I have put it in the Alert so will check again next time it pops up. regards clive.
X
Skyliner /Alan/John
Thanks again to all for the updates given
Skyliner, I assume you meant A6-ABC gone to Ural, and Alan it was not the dot in the Embraer c/n Skyliner was referring to but the number being 00524 and not 0024.
Looks like Superspotter is having fun in LOS!!! I hope he can sort out 06401E and 06403D for me!
X
Thanks X
Gotcha now, didnt notice that bit,  apologies Skyliner, its in the d/b correctly you will all be pleased to know
superspotter
Fun, That's stretching it a bit!! :) +34 and the aircon in the Sheraton has not worked for a week.....
superspotter
00B0E8, south african hex but it is a 737 operating for Jed oil 5N-BMS ex ZS-SMX, regards clive.
Thanks again Clive,
00B0E8, 5N-BMS. Boeing 737, 2R8C Adv, c/n 21710/546, JED Oil
X
Superspotter
What? they actually have occasional air-conditioning now........that's a big improvement as when I went to that part of the world in the early 80's, a big prop on the roof was all I had!!
06401E was a B744 coming into Jeddah a year ago.... it may have been miscoding though
X
X
#1763
Not populating on network
344282 ECLQK
E48997 50261M2
X
Hi X
344282 EC-LQK Airbus A320-232, c/n 258, Vueling, out of Dublin ex EI-EUP and ex Spanair
E48997 decodes to PP-JJB will be a Phenom on a test flight, may be E50P D-IMOR
YXUphoto
Quote from: Runway 31 on March 23, 2012, 08:55:00 AM
A67437  N151CC, Pilatus PC-12/45 c/n 515, Hot Mama Transport, ex N515AF
According to FAA the number change for N515AF should be to N515CC....not N151CC
YXUphoto
N16525 no longer WFU stored.
Chris11
00895B ZS-DNM C182 Cessna 182T Blue Nightingale Trading 129 CC   182-82301
#1768
Hi Mark,
Sorry correct in the d/b as N515CC, wrong on here.
N16525 was amended in the d/b the other day when you advised previously.  To get the correct info either correct manually or delete from your d/b and the correct info will be downloaded if you click on it next time you see it.
