Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 13 Guests are viewing this topic.
Nothing on that one X
Unfortunately as you know with miscodes the DHL one will come up as the A321 given that they are using the same code but the callsign will give away which is which
Hi Alan
3C4AAC id CFG670 near me now and not populating
X
A6-RRB Legacy probably hex 89634C was on box descending to AZI
X
X
I added it to the d/b around 1800.  Its not a Legacy but an Embraer ERJ 145MP, c/n 145419, Rotana Jet Aviation ex F-GUBB
Hi Rod,
3C4AAC D-ABUL Boeing 767-31BER, c/n 26259/534, Condor, ex EI-DRC
YXUphoto
00A14F callsign ZSMPI
43E905 callsign MSFAM
Morning, some unknowns from the past:
3FEF47 (Germany, no flight id)
400918 (UK, flight id: GKDMA, decoding error of 40091C)
484491 (Netherlands, no flight id, no active one found)
4CA1CE (Ireland, no flight id)
A973CF (USA, no flight id, would match to N708RT bur nothing found on it)
Some more:
3D5207 (Germany, no flight id)
A913D7 (USA, no flight id, according to airframes a known misuse of HEX by N708SA)
35AB28 (Spain, flight id: GAMC07)
3C7D8C (Germany, no flight id)
3D3A08 (Germany, flight id: DEUFO )
3E1D54 (Germany, no flight id, according to airframes D-ICHO, D-ICHO P337 CESSNA P337 Pressurized Skymaster private CN:? / Mk1EB 08/2011: http://www.flickr.com/photos/gooneybird29/6164174933/ )
3E5170 (Germany, no flight id)
Morning Mark,
00A14F ZS-MPI, Beech B300 King Air 350, no further info this time, noted passing through Gran Canaria yesterday
43E905 M-SFAM, McDonnell Douglas MD-87, c/n 53042/1969, ExecuJet
Morning Ingo,
3FEF47 decodes to D-MVOX unknown to me
484491 decodes to P4-NVB, previous holder now LX-NVB, Embraer ERJ 135BJ Legacy 600, c/n 14501002
4CA1CE unknown to me
A973CF decodes to N708RT not assigned by FAA
3D5207 decodes to D-FDHV unknown to me
3C7D8C decodes to D-AOLL unknown to me
3D3A08 decodes to D-EUFO unknown to me
3E1D54D-ICHO, Cessna T337G Pressurized Skymaster, c/n P3370288
3E5170 decodes to D-IWAQ, unknown to me
RobertMB
Quote from: Runway 31 on March 25, 2012, 10:21:50 AM
Morning Mark,
ZS-MPI: Delivery flight of Beechcraft B300 King Air 350i c/n FL-784, ex N8094L.  Photos at: http://www.aviationcorner.net/gallery.asp?registration=ZS-MPI
BR,
Robert
X
I've got another one going potty!....896226 populating as a Ryanair B738 when clearly seen as a A6-AWK a
UAE A139??
   896226                           EI-EBM  A139  Ryanair              2012/03/25 07:14:43
   896226                           EI-EBM  A139  Ryanair              2012/03/25 10:59:28
X
Even more confusing X, its in the d/b as A6-ALL miscoding.  My d/b shows that 896226 is A6-ALL A139 c/n 3150.  This was formerly A6-AWK, can you advise.  I cannot find any reference to A6-AWK
How what you saw came about I do not know.
