Author Topic: Receiver Issue?  (Read 2364 times)
twolimatango
Receiver Issue?
« on: December 13, 2011, 08:35:54 PM »
ANRB showing only two flights (currently zero)  Is there a rest function or similar I can perform or am I looking at a duff receiver.  Set up is OK as far as antenna and PC are concerned -  I borrowed my sons receiver and it works fine in the same setup giving 120+ aircraft reports.
any similar experiences I can draw on pls?
« Last Edit: December 13, 2011, 11:10:02 PM by twolimatango »
Marpleman
  • Proper aeroplanes!
Re: Receiver Issue?
« Reply #1 on: December 13, 2011, 09:33:48 PM »
Whereabouts are you situated pal?
Sounds like you could have a "dud", when you say you borrowed your sons receiver, are you talking about another RadarBox operating ok on the same pc?
Rich
twolimatango
Re: Receiver Issue?
« Reply #2 on: December 13, 2011, 11:10:57 PM »
Yes - another radarbox on the same PC antenna etc
Re: Receiver Issue?
« Reply #3 on: December 14, 2011, 08:07:14 AM »
Has all the hallmarks of a blown filter. Contact Support and they'll give you repair instructions. It's a very efficient process.
twolimatango
Re: Receiver Issue?
« Reply #4 on: December 15, 2011, 10:42:23 PM »
Thankyou - will do.
