Author Topic: Aircraft count in Mylog  (Read 2225 times)
sherlock holmes
« on: December 24, 2011, 04:00:45 PM »
Hello,
When I check the number of aircraft in Mylog at around 8pm local time I will usually see a count of around 1000-1100 aircraft. If I check yesterdays count I generally see around 980. When I do the same thing the following evening, the count for yesterday has changed from 1000-1100 aircraft to about 980. What might be the cause of this disparity. It happens every time I check. Is this unusual? Thanks in advance and Merry Christmas to all!
Sherlock Holmes
Re: Aircraft count in Mylog
« Reply #1 on: December 24, 2011, 04:38:33 PM »
There have been several discussion threads about this in the past.  Any aircraft seen TODAY will dissapear from YESTERDAY's list, because the aircraft log is driven by the LAST TIME date/timestamp.
sherlock holmes
« Reply #2 on: December 24, 2011, 04:49:36 PM »
Thank you sir!
SH
