Author Topic: Is there an ANRB update file for Mode-S codes that I can download  (Read 2164 times)
theastra
I've checked the forums, and cant find the answer.
Basically, when I look at my daily log data, I have anywhere up to 30 lines where I have just the hexcode with no other info, except the country, populated. I will also have other lines with 1-3 random fields missing, such as type, registration. operator, etc.
Is there a file put out by ANRB, or anybody else, that can be downloaded on a regular basis as a one-stop updater, in order to get rid of this regular absence of info?
TIA,
Steven
mikek
Re: Is there an ANRB update file for Mode-S codes that I can download
« Reply #1 on: January 11, 2012, 04:20:03 AM »
The current file is at the following link:
http://www.airnavsystems.com/forum/index.php?topic=6703.0
Follow the instructions and discussion that I think are in that thread to install it onto your computer.
Normally once a month it is updated and a new topic will be created on the message board.
It is kept up to date by the great work of the volunteer database update team.
After you update, if you find and codes that still don't have a registration with them then please post them onto the following link so that they can be investigated and added to the next database
http://www.airnavsystems.com/forum/index.php?topic=6624.0
Hope that helps,
Mike
