very busy
Started by satbopper, January 27, 2012, 09:15:20 PM
satbopper
hello to you all
it must be very busy in the air,at this moment 21:11 utc i have a myflights of 497
i am in the centre of the netherlands,so what is your top of myflights
greetings
Ronnie
satbopper
ACW367
Your myflights depends on the timeout settings you have set for myflights.  The only accurate total way to compare across radarboxes is to look at total number in the daily reporter logs.
Quote from: ACW367 on January 27, 2012, 11:00:13 PM
Well, but you have to subtract the false double/multi entries -typically generated by some CRJ's- first. By the way, my maximum cleared number of flights per day was last year by the end of September with about 5800 flights. Of course the number of contacted airframes is a lot smaller, because some are contacted on up to five trips.
