Author Topic: Windows 7 64bit Driver ------ HELP !!  (Read 19680 times)
Re: Windows 7 64bit Driver ------ HELP !!
« Reply #15 on: February 09, 2012, 04:31:37 PM »
The 64bit drivers are signed. Windows 7 doesn't allow unsigned drivers.
BOATMAN1950
« Reply #16 on: February 09, 2012, 04:47:18 PM »
Ok understand. Looks like I will only be able to use the RB with XP as I have installed/un-installed the new drivers many times now with the same result.
I have read that other people have had the same problem ??!!
I'm upgrading to £d so hope I don't have issues with that as well.
Chris
« Reply #17 on: February 09, 2012, 05:00:25 PM »
Not sure what you mean sir. The majority of our customers are now on Windows 7 and a fair few using 64bit thats why we have the signed drivers.
Make sure you pointing towards the latest drivers which are signed and correct for Windows 7 64bit not any others and use the latest software version and there should be no problem.
    • Rod's RadarBox Downloads
« Reply #18 on: February 09, 2012, 05:01:47 PM »
Chris - it's something other than the operating system - I've been happily running the latest version of RadarBox on Windows 7 Home Premium 64bit for over a year - no problems at all.
BOATMAN1950
« Reply #19 on: February 09, 2012, 05:10:37 PM »
Thank a lot for the help. I will give it another go or maybe wait until I have installed the 3D upgrade.
Seems most strange as the device (RB) is showing on the PC as correctly installed with the correct drivers ( I hope ) !!
Chris
anorak
« Reply #20 on: February 09, 2012, 05:16:12 PM »
Not that I know what I`m talking about, but could there be a firewall issue?  (Just a thought)
Keep us informed of your progress, as it might help others in the future.
Best of luck,  Dave.
Dave. Exmoor, North Devon.
« Reply #21 on: February 09, 2012, 05:19:13 PM »
But earlier you said the drivers were un-signed.  That would indicate that you have the wrong (old) drivers installed.
See http://www.airnavsystems.com/forum/index.php?topic=786.0 for the drivers FAQ.
« Reply #22 on: February 09, 2012, 05:21:00 PM »
Chris,
Same here installed no problems
You should have 5 drivers in the Control Panel
C:windows\system32\drivers\ftdibus.sys version 2.06.00
C:windows\system32\ftbusui.dll  version 1.2.0.1
C:windows\system32\ftd2xx.dll version 3.01.19
C:windows\system32\ftlang.dll version 1.4.0.1
C:windows\system32\syswow64\ftd2xx.dll version 3.01.19
Is that what you have
BOATMAN1950
« Reply #23 on: February 09, 2012, 06:11:52 PM »
It appears that I 'may' have the incorrect drivers ??
In the FAQ they describe installation of the 'old' drivers (unsigned)
Can someone tell me where to find the correct drivers, as in the support page for the RB the drivers there are the previously unsigned ones as when I install them I get the warning message re they are 'unsigned' !!?
Also, when I load in the main program I get a Windows warning message that 'The publisher of ANRB403Setup.exe could'ent be verified.
« Reply #24 on: February 09, 2012, 06:36:05 PM »
Win7 64-bit drivers from http://www.airnavsystems.com/RadarBox/support.html - scroll down to the link for
http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
Instructions from that page:
Our new Microsoft Certified Driver package is now available from:
 Instructions:
 1- Download the file above;
 2- Unzip it to a folder on your computer;
 3- Disconnect your RadarBox USB cable, wait a few seconds and connect it again;
 4- When Windows prompts you to find the proper RadarBox driver browse the folder where you have extracted your drivers to;
 If the above Windows prompt box does not appear:
 1- Go to Windows Control Panel - Device Manager- USB Controllers - RadarBox - Driver -  Update Driver
 2- Point at the relevant folder and install the drivers;
« Reply #25 on: February 09, 2012, 06:39:02 PM »
Chris,
They are on the support page  http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
I ant remember if I got any but ignore any warning
BOATMAN1950
« Reply #26 on: February 09, 2012, 08:11:16 PM »
They are the drivers I have tried to install many times and for some reason do not work on my machine which is a high end i7 PC running Windows 7 Premium with no other problems.
According to my PC they are not digitally sighned !!
As a matter of interest I called a friend of mine who has had exactly the same problems trying to get the RB to work on his pc ----- he now has an sbs-1er
eyeinthesky
« Reply #27 on: February 09, 2012, 11:01:16 PM »
I remember I had the same problem, my problem was I was putting the driver in the folder wrongly,
when it asked what folder to put the driver into I put in the folder, (I was opening the folder first which was wrong. .) .
Hope it helps.
« Last Edit: February 09, 2012, 11:15:21 PM by eyeinthesky »
Using the Canon 10x30 IS Binoculars with Image Stabilisation, Brilliant job on a clear day.
Bob SEN
« Reply #28 on: February 11, 2012, 07:17:45 AM »
I might be wrong, but it sounds to me like the 64 bit drivers are waiting in the "wrong" folder (if ANRB has been installed in C:/Airnav).....
cheers
Bob
1/2 a mile South of EGMC/SEN
johnboy
« Reply #29 on: February 11, 2012, 11:39:14 PM »
Had the same problem, gave up, and now just run it on my XP laptop and Vista pc. Had problems with Windows 7 loading other programmes, so now the wife uses it as facebook seems to work on everything.
