Windows 7 64bit Driver ------ HELP !!
Started by BOATMAN1950, February 09, 2012, 09:59:43 AM
BOATMAN1950
Hi all, My RB works fine on my laptop running XP, but even after updating the drivers several times on my main PC running Win 7  64bit it is no go !!
I get an on scrreen message 'hardware checking' !!
I have tried dis-connecting the RB etc etc etc but still no go.
Device manager shoes RB as functional.
Any ides 'Please' ???
Silly question, when you say updating the drivers i presume you downloaded and installed the 64bit drivers?
BOATMAN1950
Hi Alan, thats right. I have downloaded the latests drivers and device manager shows the device is working ok, but its not !!
Can you confirm which version of RadarBox are you running on your Windows 7 machine?
BOATMAN1950
It is the early RadarBox 2009 version  s/n ANRB10200
Download the latest version from our website (click on RadarBox in the menu and support), you need to have 2010 version or the 3D version with the latest 64bit drivers.
Suggest you download the latest version http://www.airnavsystems.com/download/anrb/403/ANRB403Setup.exe and see how you get on.
I would delete the original version firs,t install the new one and then the drivers before attaching the USB cable.
Dont install to the default c:\programfiles location, install to somewhere like c:\airnav
BOATMAN1950
All done as requested but it is still the same. Device manager show device working correctly & driver ok but no go. LED on RB off all the time !!
Boatman
In Control Panel/Devices and Printers/ Unspecified is all OK or is there a yellow exclamation mark
BOATMAN1950
All OK Alan; RB is showing installed and working OK !!!
Chris
Good glad you got it working Chris.  Was wondering if your USB cable was duff
BOATMAN1950
Sorry Alan, NO its not working, I meant all ok with the driver install.
Tried another usb cable as well by the way
Chris
Chris,
If you are not getting power to the box are you USB settings ok.  Is the cable connected straight from a USB socket or via a hub?
Other than that I am out of ideas.
You mention earlier "LED on RB off all the time !!" Are you saying there are no LED lights on at all on the RB?
BOATMAN1950
Only the power LED is on. The usb LED should flash in idle (polling) state once a second as it does on my laptop running Windows XP which it does fine.
As the driver is un-signed I think there maybe a conflict when it is run on Windows 7 64bit ??!!
Chris
