Author Topic: Real time network  (Read 4682 times)
vassylad
Real time network
« on: February 14, 2012, 12:05:24 PM »
Hello how do I subscribe to the above
TIA
Mike Vass
Re: Real time network
« Reply #1 on: February 14, 2012, 12:11:22 PM »
http://airnavsystems.com/Radarbox/order.html
You can choose the different subscriptions you want there. Please note you need to have ANRB serial to hand to order.
YXUphoto
    • YXUphoto
« Reply #2 on: February 14, 2012, 06:52:02 PM »
Question:  How do I permanently disable "Share Flight Data" in my settings?  Every time I restart my ANRB it defaults back to Sharing data...don't think it is fair to keep forcing me to disable the setting.  Is there a Port I can block to stop it from happening?
Manuel Mendes
    • Manuel Brito Photography
« Reply #3 on: February 14, 2012, 11:04:53 PM »
File -> Preferences -> RadarBox tab -> Untick where it says "Share flight data".
« Reply #4 on: February 15, 2012, 04:03:13 AM »
If you have a Software Firewall you may consider to block all outgoing traffic of ANRB.exe. But of course this may cause some other functionality of software to cease function.
YXUphoto
    • YXUphoto
« Reply #5 on: February 15, 2012, 05:35:39 AM »
Thanks for the "info"...but I know how to turn it off...problem is, it works only temporarily.  Next time you restart the program, the data is being shared again.
« Reply #6 on: February 15, 2012, 08:34:35 AM »
YXUphoto,
The software is set this way and there isn't way to set it permanently , the reasons and the discussions are on the forum. Have a search for them.
vassylad
« Reply #7 on: February 17, 2012, 07:33:24 PM »
Thanks A N much appreciated
Michael
