Author Topic: Airbus A380 No Ident  (Read 4850 times)
shamrocknat
« on: February 24, 2012, 10:26:27 PM »
I'm using RadarBox 2010 Ver 3.1 offline, it does not show aircraft type for Airbus 380. Any tips?
    • Rod's RadarBox Downloads
Re: Airbus A380 No Ident
« Reply #1 on: February 24, 2012, 10:43:51 PM »
Hi shamrocknat and welcome to the forum.
The aircraft type A380 doesn't exist - you need to use Database Explorer (File menu) and change A380 to A388 in the Aircraft table.
A better idea would be to update your database via the link in the first post in this thread: http://www.airnavsystems.com/forum/index.php?topic=6749.msg76059#msg76059
The update has ALL the right codes as of that date (but not the one noted in the updates thread here: http://www.airnavsystems.com/forum/index.php?topic=6624.msg76941#msg76941  :-)
Hope that helps
« Reply #2 on: February 25, 2012, 05:50:52 AM »
You may have the same issue with the B77F, which shall be B77L, among some other Types. So the best way would be indeed the use of the Database update as Rod has already stated.
shamrocknat
« Reply #3 on: March 17, 2012, 01:44:19 PM »
Thank you to Rod & Neeron,
 will try that fix, I monitor NAT traffic & I'm trying to set alert for A380
Happy St Patrick's day
