OSM Layer
Started by Peter, March 02, 2012, 03:45:57 PM
OSM download working okay here.
Peter
Yes, just back and tried OSM, now working fine. 3D doesn't appear to work, but I usually operate in OSM, so that not a problem. However, my network total is usually 11,000 odd ships, there are 2022 at present after nearly 30 mins connection, so there is something a bit odd!
Peter
3D GE plugin working okay here.  I don't use the net work.
Peter
Have tried re-installing over the top, i.e. "repair", but still have a black screen where the 3D map etc would normally be. Reloading the plugin has no effect. The odd thing is if I actually load GE, it comes up in its own GE programme screen (as opposed to ST screen), showing all the marine traffic so cannot be the firewall stopping me using GE. The only thing that I can think of is that I read somewhere that you have to log onto ShipTrax at least every 4 weeks. That is not a problem because I'm logged in most days, but wonder if the 3D facility is authorised at the server end. I haven't used 3D for quite a while until the interesting lift last Friday, so could my 3D option have been blocked due to lack of use?
Peter
Hi Peter,
Suggest you contact support with your 3D map problem, Airnav support  [email protected]
Possibly the may require to do something at their end.
Peter
Thanks Alan, I was considering that as I have totally run out of ideas as to a possible cause.
Thanks for coming back
Peter
