Author Topic: OSM Layer  (Read 65287 times)
Peter
Re: OSM Layer
« Reply #15 on: March 31, 2012, 08:07:40 AM »
Satellite layer was back when checking @ 2130gmt on 30th March. OSM layer still broken.
Peter
Re: OSM Layer
« Reply #16 on: March 31, 2012, 08:48:07 AM »
Confirmed.  OSM still broken.  Checked wireshark, and the calls to the Airnav server look okay, so there's something on the server that isn't working correctly when doing the lookup on the OSM service.
My advice to Airnav - switch to using Google Maps.  Instead of trying to convert PNG images to JPEG, you'll be able to continue to use JPEGs, and all you need to do is:
    1. Subtract ONE from the ZOOM parameter (cz)
    2. Divide by TWO the CHART WIDTH (cw)
    3. Divide by TWO the CHART HEIGHT (ch)
    4. Use SCALE = 2 when calling http://maps.googleapis.com/maps/api/staticmap?center=[lat],[long]&zoom=[cz]&size=[cw]x[ch]&scale=2&format=jpg&sensor=false
For example - http://maps.googleapis.com/maps/api/staticmap?center=57.678632,-4.02597&zoom=10&size=598x547&scale=2&format=jpg&sensor=false
« Last Edit: March 31, 2012, 08:50:24 AM by tarbat »
patcarty2
Re: OSM Layer
« Reply #17 on: March 31, 2012, 11:34:05 AM »
Likewise
Pat
Lou
Re: OSM Layer
« Reply #18 on: April 14, 2012, 01:51:29 PM »
I`ve not had OSM for over a month now,and today the Satellite layer is not responding so all I`ve got is a blank screen,the interface is updating so I know it is not my setup.
Re: OSM Layer
« Reply #19 on: April 15, 2012, 02:28:07 AM »
Both the Satellite Layer and OSM Layer problems are totally corrected at this time.
Lou
Re: OSM Layer
« Reply #20 on: April 15, 2012, 07:42:38 AM »
Hi AirNav, how come I have neither at this time?
Peter
Re: OSM Layer
« Reply #21 on: April 15, 2012, 08:11:39 AM »
I haven't got access to OSM or Satellite maps either, 3D is the only option now working.
Peter
Lou
Re: OSM Layer
« Reply #22 on: April 15, 2012, 08:45:23 AM »
I`m using saved satellite layers at the moment,however if I move the map to follow a particular ship the layer does not update I have no OSM layers at all.
Re: OSM Layer
« Reply #23 on: April 15, 2012, 03:02:51 PM »
OSM is still not working.  It is now delivering a PNG image of the correct area to the ShipTrax client.
Using Wireshark, I see ShipTrax send this reqest:
www.airnavsystems.com/cgi-bin/ANLV_SV/anlv_sv_user.dll?UsOSMLayer=0&lat=0vvyvT2sTyBAkhik&long=yv%2FyvDSvQiZAmh6l&z=1v0%3D&w=1v3ltQ%3D%3D&h=1vzkvA%3D%3D&skip_attr=on&format=jpeg&usverify_name=t4udy1bUSyVEkB%2Bl&usversion=ANSH128
This delivers a PNG image, NOT a JPEG.  I thought Andre said that you were going to convert from png on the server and output to jpg to Shiptrax as before.
I still think it would be simpler to use the Google Maps API !!
« Last Edit: April 15, 2012, 03:17:17 PM by tarbat »
Re: OSM Layer
« Reply #24 on: April 15, 2012, 03:51:11 PM »
Stby while we repass this one to our programmer.
Re: OSM Layer
« Reply #25 on: April 21, 2012, 10:44:33 AM »
Looks like this is now fixed.  I'm seeing OSM maps downloading, and using the new OSM format.  Well done development.
                                NEW        OLD
Lou
Re: OSM Layer
« Reply #26 on: April 21, 2012, 11:22:51 AM »
Working here also, the projection is not correct in some sections in my area and its a bit washed out but great to have it back,Thanks Airnav
Re: OSM Layer
« Reply #27 on: April 21, 2012, 02:42:47 PM »
Lou, do you have an example of the projection being incorrect?  And what Projection Method do you have selected in MENU - MAP - PROJECTION?  I use Mercator, and that should be okay, unless you are zoomed out to a large area in which case it can be impossible to completely map OSM onto the Airnav globe.
Lou
Re: OSM Layer
« Reply #28 on: April 21, 2012, 04:28:44 PM »
Hi Tarbat I`m also using Mercator, its a bit like when you transition Google Earth to Street view the map seems to fold over, it only happens on the central London section so I`m not to bothered.I live just over a Nm north of Blackwall Reach on the river Thames so I`m mostly zooming in to the many small docks and piers that the small coasters pull in to,at the moment I`ve got 74 targets on screen
Peter
Re: OSM Layer
« Reply #29 on: September 09, 2012, 08:02:35 AM »
OSM layer not working again. Tried 3D, that is just a black screen. A little frustrating when I have 199 ships in my own area due to the exceptional lift conditions.
Peter
« Last Edit: September 09, 2012, 08:10:00 AM by Peter »
