Started by orkney, April 06, 2012, 10:35:27 AM
X
I have seen lots of reports that the next batch of flyDubai B738's are registered A6-FAA/B/C/D....one little problem is that they are current registrations used by Fujairah Aviation based in Fujairah!!!
A6-FAA   C172   FJR 18/5/12   Private
A6-FAD   PA34   FJR 18/5/12   Private
X
Thanks X
48433D P4-PIF, Bombardier BD-700-1A11 Global 5000, c/n 9346, Arab Wings
Dont suppose you know what has happened to P4-AOD?
X
#1247
P4-AOD British Aerospace BAe-125-700A c/n 257153 opb Evolga was written off 2/1/06 at Kharkiv Ukraine  with 3 fatalities.
X
Alan,
Looks like Airbus A320-214 c/n 2807 EC-JSK is now operating for Iberia Express and not Iberia. It's just approaching Alicante from Madrid as IBS2420
Thanks Ian, changed it a short time ago, noted the change on Skyliner
X
#1251
8BE301 RKM300 showed up tonight, I believe we may have another serial miscoder in our region as it should be 896301 A6-RKB already with two miscodes known, this would make three too date!
X
flygfantast
#1252
Not populating:
142C2D RA-11309, Antonov AN-12BP, c/n 00347510, Irkutsk Aviation Industrail Association
Note:
Support aircraft for the Yak-130 demonstrator on it's way to the UK.
http://www.flyfinland.fi/view/6721/
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks Niklas,
Please note it is just 11309 without the RA
Correct X, three miscodes for it now
paul tricker
non-populates today...
440373  OEVDK             This is a DA-42 c/n 42-319
3C6574                           no flight id on this, went over at 41,000 this am
AE2CA7  GROWL01        assumed to be another F15 from Lakenheath
Rgds
Paul
Hi Paul,
440373 OE-VDK, there have been at least 10 DA-42 frames with this registrtion previously,Diamond Test Registration
3C6574 decodes to D-AIKT, unknown to me
Guess the little ones will be reregistred X, A6-FAA has had its first flight 21/6 c/n 40254/4096
Xon
Mistake in DB: 501DC9 it's 9A-CIM not 9A-SIM other data correct (SR20   c/n 1964)
YXUphoto
0A9038   ????
4A1B4F   YR-FZO
A83610   N628XP
