No display at all on 1.4 or 1.5
Started by spotter1964, March 25, 2008, 01:24:17 PM
spotter1964
Hi AirNav
Sorry to say but I get the same problem with version 1.5
I have a new Windows Vista Dell laptop. I have had version 1.3 since last year and it works with no problems. I now have 1.5 loaded and I see no flights whatsoever on the map or on the screen listing. If I connect to the network then I do receive flights. I notice that the hardware connected flight is mainly yellow but every now and again goes red and says unconnected. This never happens with 1.3. I have had 1.3 running for 10 days or more with out logging out and the laptop connected to the internet all that period. I am happy with 1.3 except for when I saw an SBS box with the altitudes displaying in the US, which on AirNav I did not see, how is this? Please see attached.
In regard to 1.5, can you suggest anything else I might try without being too technical
When is 1.3 being sunset
Thanks Paul
[attachment deleted by admin]
Quote from: spotter1964 on March 25, 2008, 01:24:17 PM
Hi AirNav
Thanks Paul
The hardware connected light must be GREEN, otherwise the hardware is not connected correctly.  Have you got the correct AirNav USB driver installed?
I do not understand your comment regarding SBS-1 and Radarbox altitudes.  Did you see an SBS-1 in the USA where it was showing altitudes, or do you mean that you could see USA traffic from another country?
Altitude, or Flight Level is always available with RadarBox, both on the map and in the aircraft list.
spotter1964
Hi Airnav
The light is green, sorry not yellow, but it goes to Red every so often. This only happens on 1.4 and 1.5, do you have different drivers than 1.3. I am logged into 1.3v again with no problems at all. I also attach a screenshot of my display on 1.3, as you can see most aircaraft are missing their altitudes, and yes I was in the US watching a friends SBS box and he had the altitudes of all aircraft
Thanks Paul
#3
Hi Paul,
I'm not AirNav, just another Radarbox user.
The latest RadarBox USB drivers are version 2.2.4.0 although I have no idea how you can see the version in VISTA.
I can't see your screenshot I'm afraid as it is a wps file and I'm not familiar with that format.
Quote from: Allocator on March 25, 2008, 02:00:41 PM
In Vista, use Device Manager, and under USB Controllers you'll see AirNav Radarbox, with properties:
#5
Looked at your screenshot, and 50% of the aircraft have altitude, which is probably about right.  Not all aircraft transmit position and altitude information.
In the SBS screenshot, a lot of aircraft show 0ft.  That does not mean they're all on the ground, since in SBS1 Basestation aircraft that don't transmit altitude are wrongly shown as 0ft.  In Radarbox, these are correctly shown as blank.
I suspect what you are trying to say is that you are not seeing altitude for aircraft which are just mode-s only (only appear on the list).
If this is the case, firstly can you confirm when you bought RadarBox? As Our first thought it that you bought before 1.3 and upgraded to 1.3 but did not do the correct firmware upgrade or drivers.
spotter1964
Hi Airnav.
I bought the box last year. One of the first to be delivered. I have looked at my drivers and the version is 2.0.0.0 dated 19 May 2006. Is this related to my original question of 1.4 and 1.5 not working at all except when on the network. How do I get updated drivers, please dont make it complicated!!!##Thanks Paul
Paul,
Open 1.5 then go Help -> About and tell us what the firmware version says.
spotter1964
It does not have a version next to firmware, it is blank. THe software version is ANRB15 dated 19 March
spotter1964
Hi Airnav
I think i know the problem and that is I did not know there were any patch releases or new versions, as I just dont have time to be on the forum all day or night. I am trying to load 1.3 again from your October release but when trying to copy the firmware to the Airnav folder I am unable as it vista says I dont have the rights, although I am the adminstrator, does anyone on the forum know a way around this. Or AirNav can you please send the latest version on disc so I can reload as new
Do you not advise by email new versions/patches etc
Thanks for any help
Paul
You can download and the follow the upgrade from the link below:
Once you have done the firmware upgrade once, do NOT attempt to do it again. The link above should allow you to save it to the RadarBox location and run it.
The issue regarding emailing everyone is that not all RadarBoxes are bought through us and hence we do not have all your emails. We did send announcements to those who signed up to the forum.
spotter1964
Hi Airnav
Well I tried this for several hours last night to no avail. I run vista and do not get the following instructions
Select "Install from a list or specific location (Advanced)"
- Select "Don't search, I will choose the driver to install";
- Click "Have Disk";
- Select the "C:\Program Files\AirNav Systems\AirNav RadarBox 2007\Drivers" folder;
- Click Next and follow the specified instructions
Do you have the exact steps for vista users. If I ever get this to work, do I just then download v1.5 and this will work?
Please help
Paul
spotter1964
Hi Airnav
When I try to save the firmware I still get cannot save to folder Airnav 2007 as I do not have the administrator rights. Has anyone else come across this problem
thanks paul
spotter1964
I have managed to get the firmware into the Airnav folder and am running it. At the moment I have a dialogue box that says opening radarbox, does anyone know how long does this remain there
thanks Paul
