Author Topic: what is the Latitude and Longitude auckland airport  (Read 4042 times)
crocman
« on: April 13, 2012, 04:52:08 AM »
i have just moved from uk to auckland new zealand,
i live right near airport airport,
i want to know what the Latitude and Longitude is please,
i have tryed to look and can only find 36° 59' S/ 174° 47' E
and i think this is wrong,
i need to somehow change my home town location on my air nav radar box 2009,
if someone can help me with the Latitude and Longitude and how to change it to make it my home page i would be so gratful.
regards iron
mikek
Re: what is the Latitude and Longitude auckland airport
« Reply #1 on: April 13, 2012, 05:40:36 AM »
Good afternoon,
Welcome to Auckland!
The best lat/long I have is:
37 00.48S
174 47.52E
or to enter as decimal degrees use:
37.0080S
174.7920E
If you want to find your actual house and you don't have a GPS, probably the easiest way is to find your house in Google Earth and take the lat/long from there.
To change it (I think, I've not had to do it before..) go to file/preferences in the menu bar
Then click on the Home Station Data tab and enter the lat/long in the space at bottom left.
Hope that helps!
    • Rod's RadarBox Downloads
« Reply #2 on: April 13, 2012, 10:06:30 AM »
Crocman
 I find the easiest way it to zoom in close to your house in Google Earth, and stick in a placemark pin exactly where your aerial is. (Make sure you have already set Decimal Degrees in Tools..Options.)
In the Placemark dialogue box, it shows the lat and long, and you can copy and paste those straight in to RadarBox
HTH
« Reply #3 on: April 13, 2012, 01:37:11 PM »
Just remember, if you're west of Greenwich, the second figure is preceded by - symbol, or you'll find yourself abroad!
crocman
« Reply #4 on: April 29, 2012, 04:38:52 AM »
don't know what i am doing wrong but i am putting in the numbers and i end up right out out sea
« Reply #5 on: April 29, 2012, 04:53:40 AM »
You have to enter the following numbers:
latitude (lat / pa in database explorer): -37.010094° (-37.0101 as RB Software uses 4 digits/numbers after the ".")
longitude (lon / po in database explorer): 174.788049° ( 174.7880)
