Radarbox installation path in registry
Started by dantheman, April 13, 2012, 02:46:23 PM
dantheman
How is it possible to find the radarbox s/w installation path. Is it in the registry or an environment variable? Thanks.
Dan.
dantheman
#1
During installation the following values which point to the installation path are added
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AirNav RadarBox_is1\Inno Setup: Setup Version: "5.3.7 (a)"
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AirNav RadarBox_is1\Inno Setup: App Path: "C:\AirNav RadarBox"
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AirNav RadarBox_is1\InstallLocation: "C:\AirNav RadarBox\"
Is this Wow6432Node specific to 64bit windows or is this HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AirNav RadarBox_is1 the same for all installations? Basically I want to be able to determine the software installation path for any installation.
Dan.
dantheman
Dan.
#3
On Netbook with WIN7 Starter it is:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\AirNav RadarBox_is1\Inno Setup: Setup Version: "5.3.7 (a)"
~Inno Setup: App Path: "D:\Programme\AirNav Systems\AirNav RadarBox" <- of course this depends on were you actually have installed it.
~InstallLocation: "D:\Programme\AirNav Systems\AirNav RadarBox"
Will check my WIN7 Desktop PC on weekend.
