Future Version - Suggestion
Started by FACTflights, May 14, 2012, 12:57:13 PM
FACTflights
If anyone is working on a future version of ANRB:
What about including a feature that will allow annotation of outlines, the positions and direction of which can be altered.  Something like the degrees that are in the Radar Rings.
Motivation:
Operators that listen to the air band would be able to see the boarders of the different radio frequencies and be able to identify them as: ATC Approach; ATC Tower; ATC Ground and so on, like they are on the aeronautical charts.
There could be many other uses for such a feature.
John
ZS1AGH
No HF antennae at the moment.
FraserSoft
I would like to be able to undock the radar screen onto my second monitor as 1 screen is far to cluttered.
Brimon
If you are using two similar sized monitors try Ultramon.It allows you to spread over the two monitors & with a bit of tweaking it can be quite good.
Chasing the heavies from a secret bunker in Scotland
FACTflights
I also run other equipment, like eg an industrial embroidery machine, from my network.
It would be handy if there were a pause facility in ANRB.
ANRB interferes when data is transfered to the serial ports because of timing.
John
John
ZS1AGH
