help is airnav pro compatible with windows 7 ultimate
Started by airnav1967, June 12, 2012, 10:35:02 PM
airnav1967
hi Can anyone help, my pc needs upgrading and im getting windows 7 ulitimate put on it as my xp is giving me problems does anyone know if airnav pro works on windows 7 if it does not does anyone know how i can get round it , just its an expensive bit of kit if you know what i mean , please any hellp would be appriciated thanks
I love aviation and the air nav is the best invention ever
Yes - RadarBox works fine with Windows 7. Download the latest software from the top of the Downloads page here http://www.airnavsystems.com/RadarBox/support.html
And, assuming you're getting a 64-bit computer, also download the 64-bit drivers from the bottom of that page.
A quick forum search will guide you through the driver installation process if you're not sure, and then you'll be in business.
Remember that if you've already done two installations of RadarBox, you may need to contact Support with your Box number to allow a further installation on your new machine.
Hope that helps
And very important never install ANRB Software in the "Program Files\" folder. Always use a different path to avoid problems with virtual store.
airnav1967
thank you this is good news i may call on services of this forum if im stuck, but  hopeing all goes well when i change my pc  in the next few weeks.   Im gettiing it upgraded in a few weeks time i could not bare to loose my airnav  cheers
Make sure you copy your Mylog Db.3 file as well and replace the new one with it when you re-install in your new computer.
airnav1967
please help i today have upgraded my pc to windows 7 ulitimate 64 bit, 8 gig memory i5 quad processor, tried to reinstall airnav
  software gone in ok but need to update drivers gone to the link that has been put in one of these messages  downloaded latest driver for 64 bit windows but when i try to update it just says windows cannot find driver please help please
The 64bit drivers are zipped.  Create a folder somewhere such as your desktop, unzip/extract the drivers into it.  Then when windows looks for the drivers direct it to the folder you just put them into,
airnav1967
thank you Alan im not sure i understand but will give it a go thanks
airnav1967
OMG Alan if i could see you i would  kiss you, dont take that the wrong way, thanks i m not sure how i did it  but it works thank you very very much x
