Author Topic: Air Europa  (Read 2155 times)
Air Europa
« on: July 02, 2012, 08:10:48 AM »
Air Europa would appear to have acquired an EMB145 for operating specific short haul routes into smaller airports. The problem is that it is operating under the ICAO of 'UX' instead of the usual 'AEA'. I am able to look up the particular route being flown when it appears on 'My Flights' and enter the information into Database Explorer but when I go onto 'Process Hardware Flights' the route information does not appear against the flight number in 'My Flights'. This problem does not occur with any other route (so far). Is there anything else specific which should be done to get RB to accept these 'UX' routes.
It should also be noted that 'UX' code does appear in column 'C2' of the airlines table against Air Europa in Database Explorer therefore I would have thought that this code should be getting recognised.
