Radarbox dimensions
Started by dantheman, July 06, 2012, 09:44:49 PM
dantheman
Wondering what the dimensions of the radarbox are exactly , height, width, depth? Also, is the usb port usb 1 or 2.0? Thanks in advance.
Dan.
neroon79
height:22mm
width: 105mm
depth: 124mm
Regarding the amount of Data that is transferred from Box to Computer in high traffic areas I doubt, that the speed of USB 1.0 (USB 1.1) is high enough to led the Box work flawlessly. But I'm not able to test is, because of the lack of an USB Port type of 1.0(1.1).
BR Ingo
11.75nm ESE of EDDV
HW:
Cable: 25m of ECOFLEX 15+
NB: Asus P53E 24/7 op.
PC: 28"4K + 24" Monitor
AirSpy mini @RPi3
pjm
#2
Quote from: dantheman on July 06, 2012, 09:44:49 PM
USB 2.0 - 12  Mbps (USB 1.0+)
dantheman
Dan.
