Started by orkney, July 22, 2012, 07:26:17 PM
Kenny,
For the routes my suggestion is to wait for the next Navdata update.  If adding them onto your own system make sure you time stamp them as I believe that is required. Any you add will only appear on your system.
Flieger_NDS
Quote from: neroon79 on August 13, 2012, 04:30:41 AM
Quote from: Flieger_NDS on August 12, 2012, 07:49:31 PM
There was no affront intended, but with neroon79 being so close to Hannover, I would have thought he might have guessed it as well that D-CAWB is the latest jet for Aerowest, as they are based there.
How did you guessed that this one is owned/operated by Aerowest? I wasn't able to guess that. Neither by using the registration nor by using the airframes hex.
I was very lucky, because I found the descent-profile of D-CAWB into EDDV the day you noted it the first time. Then I was summing up the details: delivery flight into Hannover and the reg is extremely similar to another jet of Aerowest (D-CAWM, Citation XLS+), hence it most likely was a new jet for them. Since then I was waiting for a photo of it or official announcement by Aerowest.
Hi Ingo,
3FF02D D-MOVF, yes seen on screen many times
4A0923 decodes to YR-BIC which is now VT-SGK with SpiceJet
Noted the operator info
Flieger,
There is no room for guessing when adding to the d/b, if not confirmed it isnt included
Another recurring guest here is D-CAWU. That's a quite similar reg too, but this one isn't owned by Aerowest. This time your hunch was correct. But in many times these kind of hunches won't be correct. I learned this in the past five years. So I've decided to post guesses only with big commercial airlines based on their hex/reg fleet structures.  With all others I proceed the way you did: Waiting for official announcements ore pictures, if the aircraft is labelled. But I don't actively search for them. Usually I find this Updates by coincidence while looking for other things or during updating activities. If you have the time for recurring searching sweeps of this type: I only can say the better for us all.
Just received this one:
3FF1A5 (Germany, flight id: DMEEO, no luck with the details.)
I cant find any details either Ingo
#292
Evening, the unknowns from today:
38099A (France, Flight id: AIB01AT, ferry flight of Thai Airways International A388 from, LFBO to EDHI. MSN 100 Test/Temporary reg: F-WWAT, HEX/REG should be added as Airbus Test Registration Various (A380) Airframes
/ source: http://forum.flightradar24.com/threads/1852-Testflights-AIB-****-HAM-%28and-other%29-letters-A-z-fase-of-test/page38?s=607394a853e599888c9ffbd801db30fb)
391543 (France, no flight id, was F-GFKD A320 of Air France CN014 depending on source this one is scrapped/stored since 2010, could find anything about a new one with this hex/reg tie-up)
3C48E8 (Germany, no flight id, was D-ABGH A319 of Air Berlin, this one is re-reged to HB-JOY and transferred to Belair. Nothing about a new one with reg D-ABGH/3C48E8)
3D23E1 (Germany, flight id: DELVL, D-ELVL PA46 Piper PA-46-350P Malibu Mirage Private CN:? Eye-balled seven day ago at EDDV: http://www.flugzeugbilder.de/show.php?id=1161538 )
3F0472 (Germany, flight id: D9179, D-9179 ARC? Schempp-Hirth Arcus ? used by FG Oerlinghausen CN:? http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=1DA61716D1E5F18FFA8DA262D183F08B?dsId=2613165
EDIT:
3FF02D (Germany, flight id: DMOVF, two times today)
440488 (Austria, flight id: MJF702, decoding error of 44048C)
4CA296 (Ireland, no flight id, no active airframe found)
AE2CE8 ( USA MIL, flight id: DEFAULT)
AE2D14 (USA MIL, flight id: INDY02)
C61F97 (No allocation, flight ids FIN14R & FIN38R, obviously a miscoded Finnair airframe)
MIL List:
3EA71B  GAF674
3F41AE  GAF643
3F5542  GAF787   EGWU-LFBD
3F735A  GAF959
3F8300  LIFTER2
3F86E5  LIFTER1
3F8D5C  GAF626   EDDL-LIRF
3F9A43  KAZY8
3F9A43  LIETER3
3FAFE5  EIFEL
That's all for now. Have a nice evening.
#293
Hi Ingo,
391543 was F-GFKD A320 broken up for spare, maybe re-using the box and havent re-coded it?
3C48E8 was D-ABGH A319 of Air Berlin, now HB-JOY, miscode old hex ?
C61F97 possibly 461F97 OH-LZB miscoded
Quote from: Runway 31 on August 13, 2012, 06:52:26 PM
Negative. HB-JOY is in my list (today 3-times / 3 flights) using correct. A decoding error might be possible. But without flight id almost no chance to figure out if it was one and which airframe caused it.
About F-GFKD: Could indeed be a case of inconsequential recycling of parts or it's a good old case of a decoding error.
QuoteC61F97 possibly 461F97 OH-LZB miscoded
OH-LZB did FIN38R with correct hex at nearly the same time as the miscoded airframe did today.
Thanks Ingo,
Looks like the Finnair is sending out 2 codes at nearly the same time
Quote from: Runway 31 on August 13, 2012, 07:14:46 PM
Thanks Ingo,
Sorry there was missing one word in my text. Brain is faster then fingers syndrome.
OH-LZB did FIN38R yesterday with correct hex at nearly the same time as the miscoded airframe did today.
Confirming required:
3D21E1 D-ELVL has populated as Piper PA-36-350P Malibu Mirage is this correct? Should be Piper PA-46-350P Malibu Mirage aren't it?
