Started by orkney, July 22, 2012, 07:26:17 PM
0 Members and 30 Guests are viewing this topic.
Morning, some additional unknowns from yesterday evening:
3C493C (Germany, no flight id, second time received. Again no luck with the details)
44D233 (decoding error of 44D033)
44D233 (either a decoding error caused by 44D23A or 44D23B)
4CA76B (decoding error of 4CA76A)
Have a nice Day!
BR Ingo
GreekSpy2001
noted this today
   AE1191  SPEED31                  03-0016 C560  US - Army            2012/08/14 13:26:37
however this callsign was reported as an F-15 out of LN today.  So hex probably needs to be changed to TACTICAL.
Graham
Graham
AE1191 is the code allocated to the UC-35B.  However a look at the mode-s forum logs shows that is appears to also be in use by an F-15 as you state.
Yesterday AE1191 was noted by a box in Atlanta US no callsign noted and in Middlesex and the Netherlands using callsigns BOLAR31 and GINIS31 so looks like the F-15 is miscoding
Will amend thed/b and change the details to read in use by various aircraft
Evening, the unknowns from today:
3CD055 (Germany, flight id: GFD91, decoding error of3CD05D)
3D32D6 (Germany, flight id: DERMS, no luck with the details)
3D3FA2 (Germany, flight id: DEMIS, D-EWIS RV6 Vans Aircraft RV-6 Private CN:? Mk1EB Jan 2012: http://www.luftfahrtclubbraunschweig.de/picdb/Swen-E-Johannes-Privat-Vans-Aircraft-RV-6-D-EWIS-BWE-Braunschweig-Wolfsburg-7927.html )
3FF04E (Germany, flight id: DMKKZ, still no luck with the details)
3FF0F4 (Germany, flight id: DMYPS, D-MYPS Mk1EB 2012: http://foobla.wigbels.de/wp-content/uploads/2012/05/DSC03561.jpg )
4780A6 (Norway, no flight id, nothing more)
AE2E5B (USA MIL, flight id: STICK02, various)
E09B31 (Argentina, no flight id, seems to be miscoded MIL airframe(s) )
MIL List:
3E9FD1  GAF626   EDDL-LIRF
3E9FD1  TA70
3EB870  BU23T
3F7520  GAF777
3F7520  TA68
3F8A79
3FA30C  LIFTER3
That's all for now. Have a nice evening!
BR Ingo
Hi Ingo,
3D32D6 (unknown to me
3D3FA2 already in d/b
3FF04E D-MKKZ, Evektor EV-97 EuroStar c/n EV97-0253
3FF0F4 D-MYPS Mk1EB 2012: http://foobla.wigbels.de/wp-content/uploads/2012/05/DSC03561.jpg ) anyone able to ID aircraft type please
4780A6 unknown to me
AE2E5B (USA MIL Tactical
E09B31 Netherlands - Air Force F16 but no details known
3C493C unknown to me
Thanks again and have a good evening as well
Northern Watch
Quote3FF0F4 D-MYPS Mk1EB 2012: http://foobla.wigbels.de/wp-content/uploads/2012/05/DSC03561.jpg ) anyone able to ID aircraft type please
Evening Alan
Looks like a Pipistrel Sinus to me.
Keith
Morning, some additional from yesterday:
3D3FA2  D-EWIS does not populate and do disappear from local db after manual adding and using the populate function of MyLog.
3FB1D1 (Germany, no flight id, nothing more)
3FF1B5 (Germany, no flight id, nothing more)
4784C6 (Norway, no flight id, nothing more)
89613A (UAE, no flight id, nothing more)
A9ED8A (USA, no flight id, decodes to N739LX, nothing about a new airframe using this Reg. Maybe a decoding error again.)
That's all from yesterday.
Have a nice Day!
Kenny
Quote from: Runway 31 on August 13, 2012, 07:14:38 AM
Kenny,
For the routes my suggestion is to wait for the next Navdata update.  If adding them onto your own system make sure you time stamp them as I believe that is required. Any you add will only appear on your system.
Not sure when the new Navdata will be released.  Just a heads up on route.
Starting Oct 1,2012 all Thai Air Asia (AIQ) flight will operate from VTBD instead of VTBS.
http://www.airasia.com/th/en/latestnews/bangkok-move-don-mueang-airport.page
ANRB 3km north of VTBD
flygfantast
Alan,
Not populating C61F97 using c/s of Finnair, appeared for the first time this monday (FIN14R) and was using ADS-B.
Niklas
Cable: Ecoflex-10 (10m+1m)
X
#311
Unknown MOW regular miscode 7FF3FF uses c/s GABLESEN which is common on USN C2's so very unlikely to be in Moscow, however looking back at last two years GABLESEN was used by the following TU3 on four occasions and was seen on deck at DME on Monday.
150026  GABLESEN                 RA-65574 T134  Kosmos Aviation C... 2011/02/09 18:11:46
It could now be miscoding as I have not picked RA-65574 going in our out, but cannot give 100% verification.
X
Hi Ingo,
3D3FA2  D-EWIS RV6 is in the d/b being added 13:28 29/05/2012, checked my d/b explorer and its their so have no idea why you dont have it in yours.
3FB1D1 unknown probable Mil tac
3FF1B5 unknown to me
4784C6 unknown to me
89613A unknown to me
A9ED8A N739LX, presumed decoding or miscode
Kenny,
The updaters dont add routes these are generated from what  I cant gather automatically from where the sysytem sees the aircraft landing and departing and from various routings sources.
Other
Hilas,
Suggestions elsewhere that C61F97 possibly 461F97 OH-LZB miscoded but Ingo suggests otherwise and nothing confirmed.
