Started by orkney, July 22, 2012, 07:26:17 PM
0 Members and 9 Guests are viewing this topic.
Hi Ingo,
As per reply 818
8960FA  A6-EDY  A380-861  c/n 106  Emirates
8960F9  A6-EDX  A380-861  c/n 105  Emirates
Kenny
Shahjalal International Airport
IATA: DAC – ICAO: VGHS
was renamed from Zia in 2010
http://en.wikipedia.org/wiki/Shahjalal_International_Airport
ANRB 3km north of VTBD
Kenny,
I have amended it in the d/b.  Please note that similar to your last request it wont change the info on the map.
X
#828
* 4844AC  KZR297   UAAA-OMAA                                          2012/10/02 22:14:33
Shows up as P4-NUR type not known BUT is it P4-NUR Hawker 850XP 258982 or areuse of hex/reg
X
Kenny
Quote from: Runway 31 on October 02, 2012, 03:39:46 PM
Kenny,
Alan,
understand about the map...
thanks
X
Quote from: X on October 02, 2012, 07:17:10 PM
X
Believe it might be an E190 of Air Astana reusing hex
X
I dont have anything on it X.  P4-NUR is now with the Pakstan Navy
Other than the new one delivered in September I havent heard of Air Astana getting another E190
X
#832
What about P4-KCG 19000543 Embraer ERJ-190LR which is not in db?
X
X
I think we might have a new double coder on our hands...using same flight number/route at exactly the same time as the one claiming to be P4-NUR!
   4844A4  KZR297   UAAA-OMAA       P4-YAS  A319  Air Astana           2012/10/02 22:13:53
X
Xon
#834
Two imho misstakes in DB:
MS   AR   AT   AN   AC   CN   PT   LK   PT2   LK2   CO
440137   OE-UDV   DA42   Various DA 42 NG Airframes   Diamond Test Registration   VARIOUS   ""   ""   ""   ""   ""
4401AB   OE-UDW   DA42   Various DA 42 NG Airframes   Diamond Test Registration   VARIOUS   ""   ""   ""   ""   ""
4401AD   OE-UDX   DA42   Various DA 42 NG Airframes   Diamond Test Registration   VARIOUS   ""   ""   ""   ""   ""
Today all 3 had fuel stop in Warsaw (EPWA):
OE-UDW now 44055B
OE-UDV now 44019E
OE-UDX still 4401AD
No other DA42 in range between few minutes before landing and few minutes after take off.
Morning, the unknowns from yesterday:
3C658A (Germany, flight id: DLH4EN, decoding error of 3C6588)
3C6609 (Germany, flight id: DLH3NM, decoding error of 3C6619)
3C6609 (Germany, flight id: DLH8FA, decoding error of 3C6601)
3CF476 (Germany, no flight id, decodes to D-CTWO, no new details)
3E9E2E (Germany, flight id: CB02, might be MIL airframe)
3FECDA (Germany, flight id: DMSLH, D-MSLH C42 Ikarus C-42 FB100 Private CN:? source: http://www.airport-data.com/aircraft/photo/606175.html )
43E940 (UK, flight id: MVITO, M-VITO H25B Hawker 800XP AC: ? CN:? source: http://www.homepages.mcb.net/bones/Manx_Register/ManxRegister_ModeS.htm )
44F079 (Belgium, received again without flight id)
473414 (Hungary, flight id: WZZ1QB, decoding error of 473410)
4844E5 (Netherlands, no flight id, airframes: PH-3Z1 BREZ Aerostyle Breezer C J-H- van Klinklen 057, This says it' s cancelled in 2011: http://www.antonakis.ca/registers/netherlands/20110914.txt )
4B1625 (Switzerland, flight id: SWR105L, decoding error of 4B1621)
7808A4 (China, flight id: CCA932, decoding error of 7808AC)
A528A1 (USA, flight id: UPS283, decoding error of A528A5)
MIL List:
3F4F1A  GAF062
3F63F3  TA20
3F9601  SNIPER02
3F97C1  TA43
3F97C1  TA43T
3F9E39  GAF320
A lot of decoding errors yesterday.
Have a nice Day!
Thanks X
GAS and Airframes dont have anything on P4-KCG.  AvDb have details but not hex yet and note it is due October, so I dont think it has been delivered yet.
I consider it is likely that it is haveing problems ith an iffy transponder double coding like you state.
Hi Xon.
Thanks for that.
OE-UDW definately used 4401AB previously, although I am aware that 440BB8 has also been used as well.  9 previous uses of the registration by DA42 at least
OE-UDV, been used by 14 DA42 and 2 Katana so far at least
OE-UDX been used by 9 DA42 and 3 DA40 at least so far.
Hi Ingo,
3CF476 D-CTWO, Learjet 35A, c/n 35-504, no owner details available
3E9E2E doesnt decode, probable mil as you state
43E940 M-VITO H25B Hawker 800XP
44F079 Belgian Air Force F16, unconfirmed
4844E5 decodes to PH-3Z1 BREZ Aerostyle Breezer cancelled and now an unknown on German register
Have good one
X
4BCB41   TC-RZA CL30 c/n 20284   2012/10/03 15:49:05
X
