Author Topic: Database Update Requests  (Read 567479 times)
jim_stockwell
Re: Database Update Requests
« Reply #840 on: October 03, 2012, 04:43:24 PM »
748035 reg OO-TAL a CRJ2 appears to be back in use again as it went into Luton this evening about 1720
Jim
« Reply #841 on: October 03, 2012, 04:53:14 PM »
Cheers Jim, now with Emerald Jets
jim_stockwell
« Reply #842 on: October 03, 2012, 05:42:28 PM »
Hi Alan
A typo in my last message, I think, OD-TAL rather than OO-TAL. ( The eyes are not what they used to be so causing the mix up when I read it off on approach)
Jim
« Reply #843 on: October 04, 2012, 04:21:07 AM »
Morning, the unknowns from yesterday:
44061B (Austria, no flight id, nothing more)
4492E0 (Belgium, no flight id, nothing more)
451E88 (Bulgaria, flight id: LZB461, decoding error of 451E8C)
478346 (Norway, no flight id, maybe a decoding error again)
4CA76B (Ireland, no flight id, last time it was a decoding error)
896267 (UAE, flight id: FDB9750, FDB: FlyDubai, seems that A6-FDD is back after being leased to Transavia Airlines using reg PH-FDD)
E00000 (Argentina, no flight id, miscoded airframe or broken transponder)
That's it for yesterday.
Regards Ingo
« Reply #844 on: October 04, 2012, 07:51:14 AM »
No problem Jim, I took it to be OD-TAL given the hex
paul tricker
« Reply #845 on: October 04, 2012, 07:55:40 AM »
No longer stored, departed Hanover this am, although who MHV are has defeated me..
3CC629  MHV331                   D-CCIR  D328  WFU Stored (ex Ci... 2012/10/04 08:36:49
Paul
« Reply #846 on: October 04, 2012, 07:57:02 AM »
Hi Ingo,
44061B unknown to me
4492E0 unknown to me
896267 noted as back to A6-FDD
« Reply #847 on: October 04, 2012, 07:58:29 AM »
Thanks Paul,
MHV = MHS Aviation, radio callsign Snowcap
« Reply #848 on: October 04, 2012, 09:35:40 AM »
Thanks Paul,
Thank's for this intel. I was about to ask this too, because I had monitored this airframe for a couple of days by now. It seems to be a permanent/daily connection between EDDK and EDDV.
X
« Reply #849 on: October 04, 2012, 03:13:49 PM »
7231D1 c/s IRM5040 level at FL320. hex code says is North Korean but c/s is Mahan Air.
Based on other EP miscoders 7335D1 EP-MNQ miscoding is nearest I can think off...is it bringing the triggers from North Korea, ho ho!
X
« Reply #850 on: October 04, 2012, 03:23:53 PM »
X
I saw it and was just going to email you to see if you knew what it was a miscode of.  Will wait to get confirmation on it
Chris11
« Reply #851 on: October 04, 2012, 07:16:21 PM »
ZS-SWV   00B1EA      E135   Embraer EMB-135 LR   S A Airlink   145737
« Reply #852 on: October 04, 2012, 09:19:51 PM »
Thanks again Chris,
« Reply #853 on: October 05, 2012, 06:23:46 AM »
Morning, the unknowns from Thursday:
073408 (no allocation, no flight id, decoding error or a miscoded airframe)
3C4969 (Germany, no flight id, was D-ABKI which is now C-GBKI)
3C78C5 (Germany, no flight id, was D-ANFE which is now EI-FXI)
3E86B7 (Germany MIL, flight id: GAF183)
3F8BD6 (Germany MIL, no flight id, nothing more)
One from Austria that's good for generating the numbers for next lottery:
440651  H2GK81P                                                     2012/10/04 19:56:23
440651  K17LH1P                                                     2012/10/04 19:56:03
440651  M3WIX1P                                                     2012/10/04 19:53:20
440651  M4WJH1P                                                     2012/10/04 19:51:38
440651  O4OJH1P                                                     2012/10/04 19:51:52
440651  OEIRL                                                       2012/10/04 19:38:33
440651  OEIRL                                                       2012/10/04 19:51:45
440651  OEIRL                                                       2012/10/04 19:51:58
440651  OEIRL                                                       2012/10/04 19:52:53
440651  OEIRL                                                       2012/10/04 19:53:27
440651  OEIRL                                                       2012/10/04 19:56:09
440651  OEIRL                                                       2012/10/04 19:56:30
440651  Q4GIX1P                                                     2012/10/04 19:52:39
440651  R4OIX1P                                                     2012/10/04 19:52:46
OE-IRL F900 Dassault Falcon 900EX ART Aviation Flugbetriebs GmbH 118 sources:
http://www.laasdata.com/corpjet/corpjet-by-country.php?c=OE
http://www.amcarusa.com/various.htm
http://forum.scramble.nl/viewtopic.php?f=45&t=81015&start=30&sid=2d82dbb53a567ce6681835f46c1de24d
45C940 (Denmark, flight id: SAS1588, decoding error of 45C948)
4840DB (Netherlands, no flight id, still nothing more -might be a decoding error)
E0177A (Argentina, no flight id, nothing more)
Have a nice Day!
« Last Edit: October 05, 2012, 06:25:53 AM by neroon79 »
« Reply #854 on: October 05, 2012, 08:13:24 AM »
Hi Ingo,
073408 unknown miscode
The lottery number generator was added last night
4840DB I think is a miscode
E0177A also noted in Sweden by Niklas using flight ID 4686074, miscode? possible mil
