Auto Detect my location - Can I use it when I am out?
Started by ukpbz, March 28, 2008, 11:38:35 PM
ukpbz
First day with my Radarbox so apologies for the questions
So lets say that tomorrow I want to go out with laptop and RadarBox. I go to an airport 100 miles away and sit in a designated viewing area. Can I use the auto detect function to locate my exact spot? Will that affect my 'Home' Position?
Is it as simple as clicking the 'Auto detect my location' as it didnt do too good a job finding me at home :-)
Paul
No problem that's what we are here for. Auto detect uses your Internet IP address to work out your location, sometimes its pretty close other times its out by a long way. Its the best way without actually having a GPS.
However you can also set your location by selecting a town, city if you are not on the Internet by going to File -> Preferences -> Home Station Data
Roadrunner
Paul,
You can also try www.Multimap.com input your Postcode and in the resultant reply will be a grid reference, example below
Lat:   51:54:27N (51.90763)
Lon:   0:10:32W (-0.17542)
You will need to use the figures in the brackets.
Mike
How about this as a compromise:
I guess a lot of people will be taking their laptops and RadarBoxes to a selection of fixed locations, home, work, local airport, weekend haunt, etc.
Could we have a selection of 'Home' locations that we could enter and then save, and then quickly select when we set up at each location? Perhaps it could be associated with a default map for that location, too.
It would avoid having to note them all down on a post-it note!
Roadrunner
Quote from: RodBearden on March 29, 2008, 06:32:14 PM
Why not create individual maps for each of the locations you visit (e.g. Heathrow, Gatwick, Stanstead, Luton etc) and save each of these and when you go to them you can use the relevant one. I cant get too hung up on having "home" as the location when I go away from "home"  :-)
Mike
