New Navdata.db3 - 20120819
Started by orkney, August 19, 2012, 10:43:38 AM
orkney
Hello
We are now posting the Navdata ourselves. The new one can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20120819.exe
Thank you
Andrew
Please be advised update contains routes info
And it seems to me that the airports table has been corrected - many thanks, Updaters.
If I've done it right - 168076 rows downloaded in 383ms - again, many thanks!
nortonbeak
Well done the updating team :-)
Sterling work!
Northern Watch
Exceptional work once again, my thanks to the Updating Team.
Keith
dantheman
Nice work. Installation went successfully.
Dan.
tommyg
Thanks guys.  Excellent job once again.
Tommyg
Hawkeye
Many thanks from me too.
Syd
CarlosAbreu
Hi List
I manually update hundreds of routes and aircraft information in ANRB database, could you please inform if Navdata.db3 overwrite them ?
Brgds
CA
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
CarlosAbreu
Ooppss
Thanks Alan, it seems I'm going to keep the old version, if not, I will loose all work made since I use last ANRB version.
As I have ACARS working I have update hundreds of routes that cross Portugal and Spain as aircraft details in accordance with JP fleets and other net information.
Brgds
CA
Hi Carlos,
Have a look at http://www.airnavsystems.com/forum/index.php?topic=6631.0.  It may be of interest to you and assist with your query.
CarlosAbreu
Hi Alan
Thanks for information, I'll check how to use this tool !!!
Brgds
CA
jim_stockwell
Hi Updaters.
Can I add my thanks to you all. The update went like a dream and the route data has been reactivated.
A tremendous effort
Jim
