Author Topic: Deaf  (Read 3375 times)
FraserSoft
    • Alec's Place
Deaf
« on: August 23, 2012, 05:46:27 PM »
Hi I did a quick search but found nothing obvious, I am getting the feeling that my ANRB has gone quite deaf over the last month or so. At first I thought it might have been conditions but when I put up my dedicated Watson 1090 MHz ADSB aerial up I was getting about 40-60 aircraft showing with a maximum distance of about 175nm. For the last few weeks I have getting about 8 aircraft and maximum distance has been about 30nm. I am located about 15 miles from Newcastle Airport.
Alec
Lou
Re: Deaf
« Reply #1 on: August 23, 2012, 07:20:33 PM »
Hi check your connections both ends sma plugs are a bit of a pain to get right sometimes,on the Watson when you fasten the stub mast to the aerial put a strip of s/a tape around the top of the stub mast just unders the radials I`ve had some water ingress at this point on mine in the past
Lou
Re: Deaf
« Reply #2 on: August 23, 2012, 07:41:38 PM »
Or a hefty smear of silicon grease
Re: Deaf
« Reply #3 on: August 23, 2012, 07:43:24 PM »
Try another aerial as well to see if it makes a difference
    • Rod's RadarBox Downloads
Re: Deaf
« Reply #4 on: August 23, 2012, 09:18:18 PM »
I don't know how long you've had your box, but they do have a 2 year guarantee, and all early boxes are covered for SAW filter failure. Contact Support to check on this.
Re: Deaf
« Reply #5 on: August 24, 2012, 09:02:23 AM »
If its a SAW filter issue, we will replace the part regardless whether its in warranty.
We also advise everyone with a external antenna to read the link below.
http://www.airnavsystems.com/forum/index.php?topic=2759.0
