Author Topic: New Navdata.db3 - 20121025  (Read 18175 times)
vonsmalhausen
Re: New Navdata.db3 - 20121025
« Reply #15 on: October 28, 2012, 09:51:34 PM »
maybe this helps ; when i excecute the exe file of the update, it points me out to something like
c:\airnav Systems\airnav radarbox\data
delete the "data" part in this path, and it extract to the right place
vonsmalhausen
« Reply #16 on: October 28, 2012, 09:55:40 PM »
btw, if you used the standard extraction form, you should have a "data" folder in the actual RB "data" folder, containing the newest DB3 file
« Reply #17 on: October 29, 2012, 08:04:25 AM »
Once you have saved the filre, you still have to go through the installation process to extract the data.
Use windows search to look for all occurances of Navdata db.3 to see where they all are.  You obviously have more than one Airnav version and it is going to the wrong one for the data.
If you installed the origional disk and then installed the 4.03 or 3.13 versions you will have two versions in different places.  Yoy require to find the path to the version you use and only go as far as Airnav Systems Radarbox, dont go as far as data as the innstaller puts it in the data folder.  If you find the correct and wrong Navdata you could always moves the new one over and replace the older version with the new one.
What version of windows do you use.
dca
« Reply #18 on: October 29, 2012, 10:57:18 AM »
I have installed the new Navdata db as per the link in the first post by Orkney.
I now have a number of flights (inc EZY & RYR) showing route KLAX-ELXX!
Is there any good reason why this is happening please?
Thanks,
Dave
9 nm south of LGW
« Reply #19 on: October 29, 2012, 11:00:08 AM »
Can you give some examples of these to allow me to search please.  I have had a look in my d/b explorer Routes and there is no ELXX to be seen.
« Last Edit: October 29, 2012, 11:06:21 AM by Runway 31 »
dca
« Reply #20 on: October 29, 2012, 11:11:52 AM »
Please see the attached file, the offenders are highlighted!
9 nm south of LGW
« Reply #21 on: October 29, 2012, 11:40:27 AM »
DCA
ELLX, you stated ELXX in your original message.
I have had a look at those highlighted and none of them are in my database.  To have the routes displayed you must have them in your database explorer.  Have a search for these using your database explorer searching the FN field which is the flight number, the flight number and to and from point must be in the routes d/b to display
I had MAC2105 earlier and it was not displaying a route and have noted it in a spreadsheet for updating later.
As the winter season started yesterday most of my EZY flight are not showing routes.
I can only think you have a corruption of some sort and would suggest you re-install the update.  Is  anyone else exhibiting this problem?
jim_stockwell
« Reply #22 on: October 30, 2012, 06:38:04 PM »
Thank you for all efforts. Once you get the path correct, thank you Alan,any update is very straight forward
Jim
atlantico
« Reply #23 on: November 13, 2012, 04:20:59 PM »
Following this link: http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20121025.exe
I get the information "page not found"!! Some help will be appreciated. Thanks.
Luis
    • Rod's RadarBox Downloads
« Reply #24 on: November 13, 2012, 04:51:27 PM »
Hi Luis
Right-click the link and choose "Save link as..." or "Save target as..."
Once you have saved it, double-click it to run it.
Hope that helps
atlantico
« Reply #25 on: November 13, 2012, 06:36:23 PM »
Hi Rod,
Thank you so much for the answer. Unfortunately doesn´t work. My browser, by default, is Firefox. I also tested on Chrome without success! This is weird!
Luis
Ringwayman
« Reply #26 on: November 13, 2012, 07:47:22 PM »
Hi Luis,
Glad I'm not the only one experiencing this issue. I sent an e-mail to systems support yesterday and they have forwarded it on to the technical department.
I've not heard anything as of yet.
Simon.
« Reply #27 on: November 13, 2012, 07:53:09 PM »
Yes - you're right - just tried it myself and it doesn't work :-(
It used to work fine - let's hope Support get it fixed.
dantheman
    • RadarSpotters.eu
« Reply #28 on: November 13, 2012, 09:04:48 PM »
Link is still broken. Anyone got a copy? I'll gladly host it for download until the link gets fixed.
Dan.
atlantico
« Reply #29 on: November 13, 2012, 09:16:11 PM »
Hi, all,
I´m glad, finally I´m not alone ;)
Luis
