New Navdata.db3 - 20121025
Started by orkney, October 26, 2012, 02:19:22 PM
orkney
Hello
Once again, The new Navdata Installer can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20121025.exe
Thank you
Andrew
nortonbeak
Thank you most heartily for your efforts.
I for one, certainly appreciate the efforts that are required to keep it up.
Kenny
Installed without any problem..  Thanks a lot..
ANRB 3km north of VTBD
Northern Watch
Thanks again for all your efforts.
keith
vena
User since 2/2010 ARNB 4.03, Nejdek CZ, 18km NW LKKV, WIN7 32Bit Professional
Antenna:external Rama , 15m Ecoflex cable,
AV61
how many aircraft should there be in the database now as i am showing 168113
thanks
Nick
I belive it should be around 188,000.  Looks like you are still looking at an older Navdata.
Look to where you are installing too.
AV61
Thanks for that Alan  now have 188030
I appear to have a virtual store where my downloads prefer to go to so have deleted that and
now all is ok
thanks
Nick
Canonjohns40D
For me being older etc etc!!!. Where do you see the figure 188030 please? If I select the aircraft list in Database explorer I see a figure off 81134. I've proably done something wrong or looking in the wrong place? Any help welcomed.
John
John,
The figure mentioned can be found as follows;
File/Database Explorer/Aircraft  bottom left of the box it will show ******* rows loaded in **m/s
If you dont have 188,*** you are not using the latest Navdata
Canonjohns40D
#10
Hi Alan thanks that is where I am seeing the figure 81134. I have tried to downoad the file from the site here but obviously did some thing wrong. Thanks for the reply.
You need to direct it to Airnav systems/Radarbox wherever you have it installed the box software too.
Canonjohns40D
Arrrggggghhhh! I can't get this right. Off to see the match.
Give me shout later John and will talk you through it
Canonjohns40D
Hi Alan I downloaded the file and did a save as entering it into where I believe the correct Airnav folder in my C Drive? I stil have 80*** odd aircraft/ Any help appreciated.
John
