Various comments
Started by RodBearden, November 19, 2012, 06:15:36 PM
AirNav 3D Development
Hi Neroon79,
Quote
As I have two boxes:
Is it somehow possible, that if you open the feeding statistics diagrams and one is already open, the second one will be opened beneath or aside the first and directly over it?
Further I would like it to have a third diagram (or a second line in the other diagrams) that shows me the combined feeding statistics of both boxes.
I have added these requests to the future feature list. We will try to get them coded up in the couple of weeks. Thank you for the suggestion.
Another little bug - quite annoying this time...
The second row on random aircraft labels is jumping left and right erratically, often a few times a second.
An extra character or two is appearing front of the FL.
Hi Rod,
That missing character is a small up/down arrow that we show to indicate whether the aircraft is climbing/descending. I'm not sure why it's not showing in your browser. Could you try a different browser on the same PC and let me know if you get the same problem. Also, what browser type/version are you seeing this in?
Hi 3D Dev
The problem has gone away today - the arrows were happily showing on other aircraft labels while others were flashing.
I'm using Firefox 21.0, and it's all OK on IE10 as well.
Buggy Playback-Mode.
If in Playback-Mode the time-line is used to jump through the time the actually flown route isn't coloured up, but additional routing lines are drawn.
