Various comments
Started by RodBearden, November 19, 2012, 06:15:36 PM
I've turned off the RadarBox banner - thanks!
AirNav 3D Development
QuoteI've turned off the RadarBox banner - thanks!
The setting doesn't save to the server (yet) so it isn't persistent between browser refreshes. I am working on getting the setting saved to the database.
3D Dev,
There used to be an option for model type simple/detailed etc, has this been done away with as I cannot find it and I prefer to change to simple.
Hawkeye
Another suggestion/request.
Would it be a lot of trouble to show the lat/long position of a selected aircraft in the flight data panel as it is in other tracking programmes?
Syd
QuoteWould it be a lot of trouble to show the lat/long position of a selected aircraft in the flight data panel as it is in other tracking programmes?
I added a new field labeled "Position" to the Flight tab. Do others find this field useful?
Thanks Dev, appreciated
Hawkeye
Thanks, that was quick.
Syd
"There used to be an option for model type simple/detailed etc, has this been done away with as I cannot find it and I prefer to change to simple."
We've removed this option as it we want to keep things simple: if you have less than X aircraft on screen detailed icons will be shown otherwise only simple icons.
Request:
Could we have the area events ticker show the date and time of each message?
A couple of bugs here:
First, the DAL1 icon is pointing the backwards (this might be the planes' problem rather than RB24's)
Second, the aircraft type is different on the map and in the info panel. I guess the map should read B763.
#86
Any suggestion for this "routing line":
QuoteAny suggestion for this "routing line":
This one is on our list to fix.
juangelb35
Hi Peolpe
In opening RB24 i am getting this message : Google has disabled use of the Maps API for this application
And it does not load the map .....
What it would be ??
TKS
Hi jaungelb35,
Are you still seeing this error? Were you seeing this in the widget (embedded in a different webpage) or on the RadarBox24.com website? Google Maps API has a map request limit to the Maps API (1.0 requests/second/user). You may have encountered this limit somehow. Let me know if you still see this error. Please attach a screenshot including the URL you are using too if possible. You can post it here or send it directly to [email protected].
