Various comments
Started by RodBearden, November 19, 2012, 06:15:36 PM
SCANNERMAN
Have to agree with Rod beardon the trail is thr only thing that I can't get used to but apart from that FIRST CLASS job thanks
#61
Got another stray aircraft at 0/0 tonight.
Oh and BTW - I may have missed something, but I'm seeing a few aircraft with this circular icon - some do have aircraft type showing, so does that just mean that you haven't classified that aircraft type to show the correct icon?
AirNav 3D Development
#62
QuoteGot another stray aircraft at 0/0 tonight.
Rod,
Thanks for point this out. I believe I fixed the bug that let this (0,0) slip through. You will need to do a complete reload (ctrl + refresh) to get the new source files. If you still see these, let me know.
QuoteOh and BTW - I may have missed something, but I'm seeing a few aircraft with this circular icon - some do have aircraft type showing, so does that just mean that you haven't classified that aircraft type to show the correct icon?
The circle icon indicates that there is no heading information available for that flight. Previously we defaulted to 0 degrees (icon pointing up), but now we show the little circle icon.
Thanks - I just tested the Forgot Password routine :-0 - works fine!
Thanks for the Legend popup - that should prevent more stupid questions!
Suggestion - the Chat button is difficult to find - currently mixed in with options concerned with the active  flight - might it be better to put this button on the header bar?
The Filter panel keeps disappearing, especially while I'm dragging the lower Speed slider. Also, I'd like to see the Clear Filter button appear at the top of the map when any filter is in operation, not just when following a flight. Small point - when I have dragged the filter sliders back to their limits, I've effectively got no filters in operation, so perhaps you can reset/hide the Clear Filter button(s) in that situation.
HTH
Another suggestion.
Could we have decoded METAR for the airport weather report? I really can't work out the raw METAR!
I guess it would have to be in a pop-up like the recent Emergency Squawks, on a button like "Weather at AAAA" where AAAA is the active airport code.
Another thing - the Events Ticker isn't working.
(All comments based on using Firefox 18.0)
QuoteAnother suggestion.
Rod,
I made the METAR clickable (you may need a full page reload to see it). When the METAR string is clicked, it will show the decoded METAR in a little popup similar to the Squawk popup. I will discuss with the team whether we can also add a button like you mentioned to show the same info in a different popup.
I like the decoded METER much better that having to try and decode, thanks again
Thanks for that, 3D Dev!
Strange logo for this - can't see an obvious reason for it not to show the BA logo.
Another problem logo - this time an old one for JAS - it should be Jet Aviation Flight Services.
Another two requests:
1 - When I've checked "Show only these flights" for an airport, I then have to remember that I've done it, and rerturn to the Airport panel to turn off that filter.
Could you please show the main "Filter is Active - Clear Filter" in that situation?
2 - Could you show an optional map scale line (Nm, Km and Miles)? Perhaps this could be another Premium Option.
QuoteAnother two requests:
Rod,
These are good suggestions. I have added them both to the list.
QuoteAnother thing - the Events Ticker isn't working.
We're working on the ticker. Hopefully it will be back up soon.
