RadarBox Worldwide Installation Photos
Started by AirNav Development, November 29, 2012, 10:08:04 PM
Great coverage from your set up Manuel, well done
Aerotower
Thanks Alan,
Has you know I have put a filter on the xrange2 but I don't see any increase of range, but maybe better mode-s message.
Best regards,
Manuel S.
The filter wont necessarily result in an increase in range but if it works will enable better messages.
Aerotower
I know but, because I have a cellphone tower nearby, the filter will help I hope.
On Discone antenna the filter as decrease the number of aircraft's tracked, I don't know why.
Manuel
Aerotower
Quote from: Rethymnian on September 13, 2017, 02:25:47 PM
Hi Guys,
here are 2 pics of my final setup in Rethymnon, Greece (PGANRB300799). On the left is my Diamond F-23 antenna (2M TX/RX), then I have a Diamond D-777 antenna (Civil and Military Air-band Base RX) antenna and finally the AirNav MODE-S/ADSB antenna. Right now I am getting excellent results, except towards the south. After testing various setups I came to the conclusion, that the high mountains are to blame ;-)
How you get 420NM?
What is the setup from antenna to receiver?
Thanks.
Manuel S.
ea2ip
Hi, from North of Spain, Station: EXTRPI000695
Wow, I take it you have filtering in place with that mast so close
ea2ip
Yes, I put a 1090 filter, much RF from others tower and links.
Receiver from Flightaware.
#40
I see you are not set up for MLAT yet
run "apt-get update -y; apt-get install mlat-client -y; reboot" then setup the Lon and Lat in your station id profile and then will be MLAT ready
ea2ip
Quote from: Runway 31 on March 27, 2019, 02:50:16 PM
Just done ;)
Just need to wait on the rest getting done now :-))
In addition to the photos here:
http://www.airnavsystems.com/forum/index.php?topic=7298.msg246421#msg246421
A picture of the "outside" installation.
My recent installation at Lehrte (11.8nm ENE of EDDV)
Ground station IDs:
PlanePlotter: kj
FlightAware: 43465
FlightRadar: T-EDDV13 (9984)
RadarBox24: EXTRPI000440, PGANRB300066, PGANRB100307
PlaneFinder: 94504
Hardware:
RPi3 with GPS Modul for accurate time (MLAT)
Receiver: AirSpy Mini (higher sample rate than the usual SDR sticks leading to better MLAT results / MLAT position counts)
Antenna ADS-B: DPD Productions ADS-B Vertical Outdoor Base Antenna (Standard 1090 MHz ES)
Antenna GPS: Passive GPS Mouse
Amplifier ADS-B: Kuhne electronic KU LNA 1090 A TM
Amplifier/Filter GPS: AuCon A11M-NF-NM / L1FM-NF-NM
Divider/Combiner: ZAPD-20-N+
Divider/Combiner: MINI-CIRCUITS ZB6PD-2-S+
Very nice Ingo.  Needing some painting on the balcony woodwork though :-))
