Author Topic: RadarBox Worldwide Installation Photos  (Read 244691 times)
Turbo
Re: RadarBox Worldwide Installation Photos
« Reply #60 on: January 30, 2021, 01:53:29 PM »
My radio shack main intrest is monitoring aircraft on hf/vhf next is decoding acars and hfdl last is looking at aircraft on my radar displays i have Radarbox flightstick,XRange 2,Kinetic SBS-3,GNS 5890,Flightaware Prostick Blue & Orange been in the hobby around 40 years as for adsb antennas only got 3  atm not 6 due to my tower not up..
Regards Lino..
« Last Edit: January 30, 2021, 02:02:40 PM by Turbo »
« Reply #61 on: January 30, 2021, 01:57:04 PM »
Very nice set up Lino
Turbo
« Reply #62 on: January 30, 2021, 01:59:36 PM »
Thanks Alan sorry for photos for some reason when i post pictures on some sites the go that way...
Turbo
« Reply #63 on: January 30, 2021, 02:04:06 PM »
My other photo..
« Last Edit: January 30, 2021, 02:07:01 PM by Turbo »
« Reply #64 on: January 30, 2021, 02:05:34 PM »
Nice and tidy!
Turbo
« Reply #65 on: January 30, 2021, 02:08:34 PM »
It looks it from the front not the back by the way my station 500649 was linked up very happy with it..
Regards Lino..
coldridj
« Reply #66 on: June 10, 2021, 09:31:38 AM »
Spent the bank holiday on the roof replacing my useless, rusted old TV pole with a new mast. Airnav ADS-B and Comet AB-380 airband antennas on a custom stainless steel bracket that took some serious effort to get into shape.
I'm in almost the highest point in town and with the mast clear of all of the surrounding rooftops (10m above street, 124m AMSL). Seem to get particularly good coverage North and West towards the Irish Sea and Scotland, but Peak District hill shadow to the East. The polar plot covers nearly the whole of the England and most of the UK after a week of operation and I'm very pleased with the results.
https://www.radarbox.com/stations/EXTRPI027258
Can't speak so highly of the Comet antenna though, I'm relatively new to SDR (using an AirSpy R2) I can get Scottish control reliably but EGCC tower and ATIS are weak and might just be obstructed by Alderly Edge.
« Last Edit: June 10, 2021, 09:42:03 AM by coldridj »
« Reply #67 on: June 10, 2021, 10:46:26 AM »
Looking good, serious coverage!!
NHSARainer
« Reply #68 on: July 05, 2022, 05:36:26 PM »
Just joined this Radarbox monitoring of planes.
Two years ago I started my first Radio project and that is " Radio Meteor Observation " or as it is called RMO (www.rmob.org) with a RTL-SDR dongle and a DIY 4 element Yagi antenna for the frequency of 174.31 MHz.
At the same time in order to understand the SDR radio stuff I made a little 1090 MHz antenna and then it started collecting dust until two days after getting my USB Flightstick I installed the Antenna again and now it is monitoring on a 24/7 PC the planes over my location.
Below the non professional set up of the two antennas. On the top of the PVC pipe the tiny 137mm dipole for 1090MHz. The dipole is 8.3 meters over ground level and ground level is 1950meter over sea level.
BTW I am also an amateur astronomer with an Observatory in the garden of the house.
« Last Edit: July 05, 2022, 06:57:49 PM by NHSARainer »
Grüße Rainer
EXTSHA196530
highchain
« Reply #69 on: July 19, 2024, 06:26:25 AM »
Hi there,
here is mine. Station ID EXTRPI603573
Vinnant CC1090/9-PSE => 30 cm HDF 400 => Uputronics prefiltered Amp powered via USB cable => three meters HDF 400 => Sysmocon cavity filter => 10 cm HDF 400 cable=> ADSBExchange usb stick (blue) => via USB-Kabel attached to a Raspi 4 powered via POE hat-pack.
Dump1090-fa gain currently set to 20.7.
Hope you like it.
All the best, Marcus
Station: EXTRPI603573
30 cm HDF 400 cable
uputronics prefiltered amp powered via USB cable
three meters HDF 400 cable
sysmocon cavity filter
10 cm HDF 400 cable
via USB-Kabel attached to a raspi 4 powered via POE hat-pack.
« Reply #70 on: July 19, 2024, 11:42:25 AM »
Great coverage Marcus
elfranko
« Reply #71 on: August 01, 2024, 04:38:44 PM »
I have noticed that I am unable to make MLAT work from the rbfeeder.ini on my PI
I opened up another Terminal and Ran:
Code: [Select]
/usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat xx.xxxxxx --lon -y.yyyyyy --alt aaa --user EXTRPIZZZZZ --results beast,connect,127.0.0.1:32004Substituting X,Y, Z and A for Lat, Long, Station Number, Altitude.
Within a minute or two MLAT shows in the web page, but the command window shows it quicker, Image included.
I built my PI and started with FlightAware then added Radarbox, and finally got FlightRadar in it as well.
So the same box shares to all 3. I recently also got an external antenna, this has more than doubled my range.
Hope this helps
ElFranko
« Reply #72 on: August 01, 2024, 08:39:03 PM »
This is an installation photos thread so wrong place for your query, this would be a better place for it https://forum.radarbox24.com/index.php?topic=102661.0
Have you installed the RB MLAT client?
elfranko
« Reply #73 on: August 01, 2024, 09:35:10 PM »
My Apologies - I thought it was in a thread regarding MLAT
Weird - not sure what I did.
