Started by orkney, December 04, 2012, 09:11:12 PM
0 Members and 15 Guests are viewing this topic.
54901 - Jim
Oops!  Forgot one ...
A0FA7B / N162QA - NOT ASSIGNED OR RESERVED
KOSH - Oshkosh, Wisconsin USA
Thanks again Jim
Regarding A0FA7B / N162QA we both got a bit wrong.  It is in the d/b as A0FA8B and should be N162QS, Millrock Aviation Financial
X
On Network
A282C8  88 decodes to N261AV. This was/is A320-214 c/n 1615
X
Hi X
Was reregistered N218FR on 6/2 and should be using A1D7C7
X
On network
A59C13 N46007  Vans RV-10 c/n 549702
X
Blueboy
Hi Alan, picking up HEX C0884F which decodes as C-GZQC  CRJ-700 c/n 10334
J.D
mikek
43E777 populates as M-SKZL but the aircraft appears to have been re-registered as M-ADEL with the same mode S code.
Not sure if it's still the same operator.
Mike
diddyboy
Hi Alan
First one from the Sandpit this morning.
896000                                                              2013/02/24 06:40:10
Neil
X
Neil
896000 is the code used by one or many of the Air Wing Choppers...never been nailed to one particular aircraft. Over me practically everday though!
X
Hi Mike,
Yes it is the same aircraft
43E777, M-ADEL, Canadair CL-600-2B16 Challenger 604, c/n 5404, Kerzner International Management
Hi  JD
Skyliner shows C-GZQC as ferried 23 Feb13 YYM-YYR-KEF-OLB on deivery to?
Neil/X
Thanks for the info, I have nothing to add
Blueboy
Hi Alan, picking up HEX A857CD decodes as N637AR DHC-8-102  c/n 265
J.D
Hi JD,
I believe its en-route Afghanistan, just departed Prestwick
