Started by orkney, December 04, 2012, 09:11:12 PM
Hi Mike,
The route should be in without the leading zero and the software should work as you suggest.  Unfortunately there are thousands of routes in the d/b with leading zeros and unfortunately I can only delete them one at a time with the present updater but this is one of the things I hope to have improved.  In the meantime, ss I find a leading zero I delete it.
The automatic route look up routines add the flight ID that they see to the d/b and are not clever enough to remove the leading zero, one up for humans. UAE418 and UAE0418 were both added a couple of months ago by the automatic look up routines which I should add have been improved upon in the last month, although at times they still get it wrong, as does the human!!
As we can only have 3 stops in a route at this time, I have removed NZCH as it doesnt have a network contributer t this time.
Thanks again.
diddyboy
Hi Alan
Unknown from the Sandpit yesterday:
* 50817A                                                              2013/01/24 00:37:21
   AB1FBC                                                              2013/01/24 17:07:09
Neil
Hi Neil,
50817A unknown to me
AB1FBC decodes to N816AX not assigned by FAA.  Previous holder is now 9G-RAC DC-8-63F which is/was stored at Rak Al Khaimah since February 2011
Northern Watch
Good morning Alan
Just in case you are not aware and just heading on delivery:
A80DAC / N618NK / A320-232 / c/n 5458 / Spirit Airlines / c/s NKS9618
Keith
Cheers Keith, got it.
Hi Neil,
I am advised by John Hargreaves that 9R-RAC is back in the air so that would be it you picked up this morning
BOM1
Finally got around to submitting a few updates noted at the back end of last year around SE Asia.
758060   RP-C2282   D228  8173
7580C4   RP-C7255   AT75   842         CEBU PACIFIC
758069   RP-C2283   D228   8077
3CE969   RP-C4328   D328   3042       SEAIR
4007FE   RP-C7328    D328   3069       SEAIR
8A0365   PK-CLH        B735   27327     SRIWIJAYA
76E301   010              G5      5014       SINGAPORE AF
76E305   720              C130  3519       SINGAPORE AF
8A022A Shown as various in the database seen many times at CGK/KUL and SIN over 2 week period being used by PK-LGV - B739.  No other airframe seen using it.
750048 read off as 9M-FYH ATR Firefly at Singapore.  Shown in database as 750040, however that hex was not picked up.
89905B shown in database as B-22316 A320 seen several times at CGK and is PK-YVE A320 441 Batavia.
Steve
Flieger_NDS
Got a new one, picture will follow soon:
3CCE06, Hawker 750, D-CFIC, ex. N774HB, future HL7778, destined for Korea Transportation Safety Authority, currently undergoing special mission conversion for flight calibration.
Hi Flieger_NDS,
flygfantast
Not populating:
008140 (South Africa) c/s PTRJC
096108 (Cape Verde)
3F5C68 GAF-TAC
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi Steve,
Many thanks for those.
8A022A was the hex used by PK-WFJ AT75 of Wings Abadi on its delivery flight out of Toulouse hence the Various tag.  Did you see it and what hex was it using.
89905B is as you will be aware a Taiwanese hex code and was confirmed on the delivery flight in March last year of B-22316 of Transasia.  PK-YVE was formerly B-22306 until it was sold by Transasia in 2008.  One of the pitfalls of miscodes and re-issueing used ones.
Hi Niklas
008140 (South Africa) c/s PTRJC  008140 decodes to ZS-ALR, unknown to me.  PT-RJC is also unknown to me.  It was last used by an Embraer EMB-712D Sertanajo (kit built PAPA32R-301).  No dount it's true identity will become known in due course
096108 (Cape Verde) unknown to me
Chris11
00B542   268 Hawk Mk-120 Lead In Fighter Trainer (LIFT)   South African Air Force
Northern Watch
Good afternoon Alan
A couple of routes from this morning:
NVD181      BIKF - LOWS
NVD182      LOWS - BIKF
Keith
