Author Topic: upgrade from v2xx to 3xx  (Read 3705 times)
springbok
« on: December 27, 2012, 07:35:25 PM »
i have installed radarbox onto a new computer from the cd which is v2.01. where do i get the upgrade to v3.13. the links i have tried via google all do not work..
Re: upgrade from v2xx to 3xx
« Reply #1 on: December 27, 2012, 07:38:59 PM »
Its still to be connected following the server crash unfortunately
springbok
« Reply #2 on: December 27, 2012, 08:01:32 PM »
i had a copy of it on a memory stick but when i run it the box will not run, although it is running fine in v2. i have downloaded the updated drivers for win 7 but that does not help..
« Reply #3 on: December 27, 2012, 08:23:06 PM »
Are you on 64bit version if Win 7 if so you will need the 64bit drivers
springbok
« Reply #4 on: December 27, 2012, 08:31:46 PM »
yes have downloaded them but still no joy
vonsmalhausen
« Reply #5 on: December 27, 2012, 08:40:25 PM »
have a copy of the 3.13 version on my Dropbox, here's a link to download it
https://dl.dropbox.com/u/61291131/ANRB313Setup.exe
just to be sure, here is a link to a copy of the 64bit drivers to
https://dl.dropbox.com/u/61291131/ANRB64bitDrivers.zip
hope this helps you out
springbok
« Reply #6 on: December 27, 2012, 09:35:36 PM »
thanks will give them a try
springbok
« Reply #7 on: December 28, 2012, 01:56:05 PM »
Thanks they did the trick...
vonsmalhausen
« Reply #8 on: December 28, 2012, 07:16:07 PM »
no problem, glad to be of help ;-)
