Hardware connection
Started by PAULWIGGY, January 25, 2013, 01:59:15 PM
PAULWIGGY
I would appreciate any guidance on the following/
for the last ten mins I have had netwrok connection but not hardware.
Blue lights flashing on box. Is it a simple case of exiting the system or is there a simpler way to reboot the Hardware into life?
Brgds Paul
PAULWIGGY
I dont know if something wrong with coversge at the moment. Turned system off and back on and have hardward details 'my flights' showing but map blank despite traffic operating over the house.
Does disconnecting and then re-connecting the USB cable have any effect?  Is the cable direct from your computer or via a USB hub?  If its the latter try connecting it direct.
jbagra
Try another USB port or reinstall device drivers
PAULWIGGY
thanks for responses.
I thought it was a one off but just logged in again and same problem,updating 'list' on left handside working for hardware green box,kists coming up,,green box for network showing but nothing appearing on map.
frustrating
PAULWIGGY
pressed show all buton and all ok now. Maybe a default on start up.
Any ideas how to skip this , very much appreciated.
Paul
Its not a start up default Paul.  It will start up the way you left it and as you had to press the show all button I would suspect you must have had a filter on when you closed down.
PAULWIGGY
