problem after update
Started by lebelgepatte, February 21, 2013, 01:44:13 PM
lebelgepatte
hi,
i have installed the last update and i get a lot of problems now.
some aircraft don't have anny picture anymore, before they had some pics
other aircraft aren't correct anymore, some who has to be military are now on radar as civil.
somebody can help me plz
#1
Lebelgepatte, can you advise which aircraft you consider to have incorrect information and which military aircraft now appear civil?  What gives the impression they are civil and not military, is the information incorrect?  If its the flags issue, did you install the updated dat008 file as previously advised?
If you had photos previously they will still be in your photo folder and should still be shown.  If you click on an aircraft does the photo download OK?
lebelgepatte
1)can you advise which aircraft you consider to have incorrect information:
2)which military aircraft now appear civil?
* 44c1e9 G-16 md900 has to be belgian airforce
* 44ed82 m-2 Alo3  has civil flag
3)If its the flags issue, did you install the updated dat008 file as previously advised?
* i just installed the update that i can download on this forum, i didn't see a update dat008file??
4)If you click on an aircraft does the photo download OK?
* yes it download but on some aircraft that i had picture , now it is with and dont download it
plane with out picture anymore:
*44f618 seaking
*44f61A seaking
*44f143 f16
*44f829 alpha jet
*44f692  SF-260 marchetti
*44f828 alpha jet
*44f639 A109
*44f619 Seaking
*44f676 sf260 marchetti
to start up i need - 10min before i can log on on my radar is that normal?
database has 18979 logs.
Go to here and download the flags zip and replace your existing http://www.rodbearden.com/RadarBox/Downloads.htm
