New Navdata.db3 - 20130221
Started by orkney, February 22, 2013, 10:09:58 AM
orkney
Hello
Once again, The new Navdata Installer can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20130221.exe
Thank you
Andrew
Just to make sure its all went as it should, you should have around 193,610 aircraft when you check
Download spot on with 193,610 aircraft and no problems.
Thanks, guys
N9JIG
I must be doing something wrong... After I run the updater I show "82448 rows loaded in 142 ms." when I go to Edit>Database Explorer and select Aircraft. (I get 1086 Aircraft types if it matters.).
I am running Windows7 Pro, ANRB 4.03. My data folder is at C>Program Files (x86)>AirNav Systems>AirNav RadarBox>Data.
When I run the DB updater it obviously replaces the original database and creates a navdata-backup (19,030 KB) The replacement database is 48,882 KB.
Hi N9JIG,
I have installed my Radarbox to C:\Airnav and in my program files (x86) there are Airnav files also.  Why I dont know, probably something to do with Radarbox being 32bit working on 64bit windows.
As you have installed the Navdata and it is showing 82,448 rows i would suggest you have more than one NavData.db3 file on your computer. The one you should be using is 48,882KB as you state.
I would suggest you use windows search to look for NavData.db3.  In my X86 Data folder there only 2 files the NavDat.db3 and a backup. As you installed to the default location, I would suggest the one your computer is using is in program files In the correct Data folder you will have lots of files including ASssets, photos, logos, silhouettes folders, a number around 20 dat files and your Mylog files and a Navdata.db3, Navdata.db3.bak, NavData.db3-journal and a navdata-backup.db3 file.
I would suggest you move the Navdata.db3 file from the x86 data folder to the program files data folder and start up Radarbox and see what count you get.
N9JIG
Got it!  I did have it installed in the default "x86" folder and am pretty sure I pointed to this when I installed the updated DB yesterday. I did a Windows Search for NavData.mdb and came up with several (37) hits, mostly as backups in my Windows_old folder that came about when I updated from Vista to Win7P. I tried to delete these but they all (except the one in the x86 Programs folder) reported they could not be located.
I deleted AirNav via the Windows Control Panel and reinstalled it in C>AirNav and then ran the DB updater pointing there and now I get 193610 aircraft.
I appreciate the help!
Northern Watch
Thanks again Updaters, no problems here and spot on 193,610.
Keep up the excellent work.
Keith
Albatros
Download spot on with 193,611 aircraft and no problems.
Thanks, guys
Paolo
John1944
From a new member, thank you very much for the update.
John1944
nortonbeak
Thank you for all the hard work that the updating team undertakes.
