Author Topic: Any ideas ?  (Read 3438 times)
EINN-07
Any ideas ?
« on: April 06, 2008, 12:19:24 AM »
This one is certainly a brain teaser !
Two Lufthansa Cargo aircraft,  D-ALCC and D-ALCG at the same FL and with the same squawk code ! There is probably only one aircraft but how did this happen ? 'Both aircraft' were on screen for at least 30 minutes. Only regret in hindsight is that I did not check when the signal dropped. The only way I can figure it happening is that one aircraft had two boxes with separate hex codes set or that somehow two separate aircraft had the same squawk code assigned, and I don't know if the latter is possible given ATC procedures.
[attachment deleted by admin]
Marinus
Re: Any ideas ?
« Reply #1 on: April 06, 2008, 10:09:31 AM »
My best guess is that something similar is happening as recently with
KLM B747 PH-BFG(484006) who on one transponder was sending the hex code
of sistership PH-BFH(484007).....
Propably a setup error, but can't tell you for sure....
Marinus.
