Author Topic: Database Update Requests  (Read 456752 times)
orkney
  • Database Updater Moderator
    • orkney radarbox screenshot
« on: March 19, 2013, 03:11:01 PM »
Hello
This is a new Database Update Requests thread since the old one is now large and unwieldy so has been locked.
Thank you in advance for your requests.
Andrew
Re: Database Update Requests
« Reply #1 on: March 19, 2013, 06:08:24 PM »
Evening,  the unknowns from today:
3E2558 (Germany, no flight id, nothing more)
4C8A58 (no allocation, no flight id, nothing more)
A00000 (USA, flight id: EIEHP, EI-EHP: 4CA7E4 R44 Robinson R44 Raven I Private 1913 source: http://www.rotorspot.nl/ei.htm and airframes)
MILs
3EA6A4  GAF024
3F4241  GAF057   CYYR-EDDK
3F87E3  TA60
3FB53F  EAGLE1
Have a nice Evening!
« Reply #2 on: March 19, 2013, 06:19:06 PM »
Hi Ingo,
3E2558 (decodes to D-IFIM, unknown to me
4C8A58 miscode unknown to me
A00000 also saw this code earlier around San Diego with a different registration, used on numerous miscodes
Mark Coles
    • daily or weekly updates for your AirNav RadarBox
« Reply #3 on: March 19, 2013, 07:02:59 PM »
3D7AC7 D-FSTN, SOCATA TBM 850 c/n 387, Bumuller GmbH & Co
3D7AC7 decodes to D-FSTB which is what I had as a reservation for c/n 387
hth
Mark
daily or weekly updates for your database
www.dbpop.co.uk
« Reply #4 on: March 19, 2013, 07:08:04 PM »
Thanks Mark, you are correct D-FSTB is what I have in the d/b, please note Ingo although it will have populated correctly.
« Reply #5 on: March 19, 2013, 10:06:06 PM »
Out of TLS as CCA052 is - 7809A5  B-5918  Airbus A330-243  c/n 1396  Air China
« Reply #6 on: March 20, 2013, 02:43:42 AM »
Morning, thanks for the notification about D-FSTB. One addition to yesterdays list:
440663 (Austria, no flight id, nothing more)
Have a nice Day!
Northern Watch
« Reply #7 on: March 20, 2013, 08:52:42 AM »
Good morning Alan
Not populating this morning:
A95D9D / N702SS / Cessna 650 / c/n 650-0135 / Owner N702SS LLC.  This looks as if it is Ex- VP-CAR.
Keith
mikek
« Reply #8 on: March 20, 2013, 08:57:30 AM »
Not populating:
C81C40, ZK-FWA, Sequoia Falco F.8L, 651, Mr W I Thompson
Mike
« Reply #9 on: March 20, 2013, 09:30:18 AM »
Thanks Ian, it is indeed ex VP-CAR.
« Reply #10 on: March 20, 2013, 09:48:59 AM »
Thanks Mike, now added
« Reply #11 on: March 20, 2013, 09:57:58 AM »
Thanks Ingo, nothing available for 440663
X
« Reply #12 on: March 20, 2013, 12:43:44 PM »
ACE003 D328 (C-146A in d/b) no longer carries reg N929EF but has USAF marking 03026 (10-3026 the 3026 being c/n)
I am informed A74ED3 D328 (C-146A) N570EF is now Carrying 53058 (USAF ?5-3058)
X
« Last Edit: March 20, 2013, 12:49:04 PM by X »
« Reply #13 on: March 20, 2013, 01:27:35 PM »
Is it using a mil hex X or is it miscoding its civil one.  As its still on the FAA list I presume it will use a duel identity depending on its operating area.
X
« Reply #14 on: March 20, 2013, 01:31:57 PM »
They are using the civil hexes hence miscoding and as you state presumably using duel identity
X
