Started by orkney, March 19, 2013, 03:11:01 PM
Blueboy
Hi Alan, couple of questions - Had HEX 14FC0A on box as TU-204 RA-64522 but it was quoted as RA-64521 on various forums (out of Belfast) Also had HEX A0605E out of Glasgow - database shows as a Balloon N123RR but this was definately a Gulfstream of some kind.
J.D
flygfantast
#1486
Add another one to the non populating list: 4242D3 c/s RLU8405. :-)
Could possibly be VP-BVC, delivery 18jun13 ARN-VOG, all white according to Skyliner.
VP-BVC, Canadair CRJ 200, c/n 7441, RusLine ex N409CA
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi X, That being the case AP-BKS is ex EK74723 of Veteren Avia
flygfantast
#1488
Quote from: Flygfantast4242D5 c/s FLYHERE
I wonder if this could be ex N713CA or N818CA, stored for some time at ARN together with N409CA (possibly VP-BVC)
Niklas
#1489
Good Call Niklas.  It is ex N409CA which was parked at Arlanda and was cancelled to Bermuda 12/6.
The others you mention are still on the FAA register.
flygfantast
Quote from: Runway 31Good Call Niklas.  It is ex N409CA which was parked at Arlanda and was cancelled to Bermuda 12/6.
Thanks, I've posted a question on the ARNspotters forum regarding the other 2 aircraft.
Niklas
Blueboy, the Tu-214 was out of Prestwick for Belfast and given what you noted has thrown all the Tu-214 codes into confusion for me
A0605E was as you state out of Glasgow and is N12SJ A067DE miscoding
Blueboy,
Both Tu214s are airborne ex BFS. RSD031 is now in the Newcastle area as RSD031 using 14FC09 which should make it RA-64521. Sistership 14FC0A is already in Russian airspace as RSD011 which equates to RA-64522. This one overflew Prestwick and Edinburgh around the same time 14FC09 took off from Prestwick. The 2 of them in the area at the same time appears to have casued confusion.
X
Code for AP-BKS is 760973 and correct ex Veteran EK74723 (I believe Rayyan Air and Veteran are sister airlines)
X
Thanks X, got it earlier
Blueboy
Hi Alan, thanks for clearing up both questions
J.D
GreekSpy2001
Some new ones for me
* 400945                                                              2013/06/18 18:23:34
* 4406A9  OEIRR                                                       2013/06/18 23:42:39
* 43E9B3  MFLYI                                                       2013/06/19 08:04:35
Graham
Hi Graham,
400945 miscode/decode error
4406A9  OE-IRR Dassault Falcon 7X, c/n 196 ART Aviation,
43E9B3  M-FLYI  Cessna 525C CitationJet CJ4 c/n 525C-0106
diddyboy
Hi Alan
An unknown Ukraine from Yesterday around the sandpit area.
* 5082C4                                                              2013/06/18 20:59:31
* 5082C4  IRM4588                                             2013/06/18 09:38:20
Neil
#1499
Hi Neil,
5082C4 UR-CKX British Aerospace BAe 146-300 c/n E3131 UM Air/Mahan Air
