Started by orkney, March 19, 2013, 03:11:01 PM
CYYZGUY
SWG382
OK-TVS
Showing CWYG-MUVR
Flightaware showing CYYZ-MUVR
I could not find it in my database.
regards,
40" LED Monitor
40" LED Monitor
CYYZGUY
N
C-FNAG
PA-31 Piper
Showing on my screen CYYZ-KLAX
This is impossible as this is a private small prop plane
Please check
40" LED Monitor
40" LED Monitor
Flieger_NDS
Got a new one, only three messages, appears to be on the ground:
3DD662, nothing on it
Flieger_NDS
3DD662, D-HBLA, Eurocopter AS350 B3 Ecureuil. c/n 4267, A Borodachev/Alex Metal
Jason,
CUB181 routes CYYZ-MUCF-MUHA and amended as such
SWG382 amended
Regarding ACA831 this derives from the server routes look up routine previously discussed
C-FNAG isnt in the routes d/b therefore I cannot do anything with it.  Please note that the automatic systems derive a route from the previous flight that it noted the aircraft flight ID flying and adds that to the route database.  This works quite well for unknown routes for airliners flying the same route with the same flight number each time.  However business traffic and military traffic do not follow the scheduled pattern flying ad-hoc routes dependent on business requirements and while the same automatic routine will apply a route to a flight ID, in these circumstance when the flight ID is used the next time it is usually wrong.
Also please note that some airlines use the same flight ID on different routes dependent on the day of the week.  United is one such airline and their flight ID can be used on up to 3 different routes in a week, quite confusing to say the least and there is no way to have it change dependent on the day of the week so their flights can appear wrong on screen.
Charter flight are also problematic in that they can be re-used throughout the season or for different seasons depending on operational requirement of the airline concerned, again hard to keep up with all the changes.
Mark Coles
the hex code for this should be 140AF0 unless it's miscoding?
Now I got the hex, again using callsign MDN9681:
140AFC RA-02800, Beechcraft B300 King Air 350i, FL-772, Meridian+
Mark
daily or weekly updates for your database
www.dbpop.co.uk
Correct Mark,
140AFC, RA-02812, Beech B300 King Air 350, c/n FL-630, Beech B300 King Air 350
I donT have any details on 140AF0, RA-02800
Thanks Alan
Hi Alan
There's going to be a second plane on the Little Red route Between Heathrow and Edinburgh, starting on the 15th April and filling the flight number gaps:
VIR3001, 5 and 9 - EGLL-EGPH
VIR3002, 6 and 10 - EGPH-EGLL
More Jet2 Blackpool flight id updates:
EXS713 EGNH-EGAA flight id EXS713Q
EXS714 EGAA-EGNH flight id EZS714Z
EXS740 LEAL-EGNH flight id EXS740U
Mark Coles
you've confused me now, as per Flieger_NDSs post, he is tieing up FL-772 ex N8132F as Meridian RA-02800 (which I already have in my db),  but he is quoting 140AFC instead of the expected 140AF0, was wondering if this was a typo or a miscode, as you say 140AFC is  RA-02812, Beech B300 King Air 350, c/n FL-630
Mark
www.dbpop.co.uk
#445
Hi Mark,
I dont know how it was tied up, we will have to wait on Flieger_NDS to advise.  As you state 140AF0 decodes to RA-02800.  All I knew for for certain of FL-772 is that it is now registered as RA-***** and is ex N8132F which was de-registered in July last year to Russian Federation
The last RA-02800 that I am aware of is an H25B c/n 257007 which became N49RJ on 13th February this year. I can only presume that the H25B was de-registered a while before its sale to the US as here is a photo of the B350 taken in November registered as RA-02800 http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-Meridian-Beechcraft-B300-King-Air-350i-RA-02800-BWE-Braunschweig-Wolfsburg-9867.html
Northern Watch
Good evening Alan
A couple of routes from today:
EZY94KF         EGPE - EGGW
BEE6JN           EGPE - EGAC
Keith
Cheers Keith, many thanks
flygfantast
Owner/operator of SE-MEO is Östgöta Hopptjänst.
Guess I will see this a/c a lot this summer as it will be used for skydiving events near my home!
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks Niklas,
Why not give it a go yourself!!
