Started by orkney, March 19, 2013, 03:11:01 PM
lebelgepatte
1) Picture update:
Mk48 Seaking   belgium air force
44f61a RS05
44f619 RS04  MK48 seaking
44f618 RS03  MK48 seaking
A109 agusta belgium airforce
44F64F H-41
44f654 H46
44f645
44f64c H38
44g641 h27
44g649 h35
44f639 H25
44f647 H33
44f64a H36
f16 belgium airforce
44F0E7 FA-77
44f149 FA109
44g143 FA103
44f185 FA125
44f0e2 FA72
sf260 marchetti belgium airforce
44f676 ST36
44f67e st47
alpha jet belgium airforce
44f828 AT22 Alpha jet
44f829 AT19
2) DATA update:
44f692 SF260 marchetti
44f047 ??
44f643 a109?
orkney
Hello x and lebelgepatte
I cannot find any more for your one X so it will be good if you are able to find out. Sorry lebelgepatte but I cannot change photos and I cannot find any registrations for the three you wanted details for.
Many thanks again
Andrew
flygfantast
4AD6C9 SE-UVI, DG-500M, c/n SE5OM22, Norrköpings Segelflygklubb
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Niklas
As always, thank you for him.
Andrew
CYYZGUY
TSC360
Showing CYYC - EGKK
Flightaware showing CYYZ - EHAM
regards,
40" LED Monitor
40" LED Monitor
Blueboy
Hi Andrew, picking up HEX A52B0E - which decodes as N432FE Dash-8 c/n 237
J.D
orkney
Hello CYYZ and JD
They are done. Many thanks again.
Andrew
Flieger_NDS
3FEE9A needs an update. It now is D-MGTD, AutoGyro Cavalon, doing research flights for the German Aerospace Center flight division "DLR Flugbetriebe".
http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-DLR-Flugbetriebe-AutoGyro-GmbH-Cavalon-D-MGTD-BWE-Braunschweig-Wolfsburg-10329.html
X
Andrew
I made a mistake IAM f/n is Italian Air Force and NOT Mahan Air!
X
orkney
Hello NDS and X
Thanks for that change NDS, It is now done. X, An easy mistake and It is good to know that  there are at least some military aircraft that are not near here!
Thank you
Andrew
jim_stockwell
Good afternoon Andrew
Not populating is 4C4AAB which I picked up at about 1650ish at 4000ft
Jim
orkney
Hello Jim
Sorry, I can't find anything for that one.
Thank you
Andrew
knight01
not in database
hex: 406905
using callsign AWC32T/ZAP32T
Geot
Can you please add
C055D8 C-GGNF DH8D c/n 4393 of Air Canada Express/Jazz
MTIA
George
jim_stockwell
Hi again Andrew
Looking around the web, Airframes has 4C4AAB as YU-SVL. Judging from the height when I lost contact with it would suggest to me that it went into Stansted or maybe Northolt.
Jim
