No 3D
Started by 2E0FLP, April 06, 2013, 09:34:26 AM
2E0FLP
My 3D not working !!!!
I would suggest you email support as they are not online
After my Database Updating related Software shut-down and re-start my 3D isn't working either. So as Alan has stated: The Server needed for 3D authentication is either down or not working properly.
We are aware of an issue on the server causing instability, we aiming to get this rectified asp.
Should be working OK now. Please confirm.
Confirming 3D is working.
Yes 3D OK now
ricclar
I have had no 3D for over twelve hours.  Can this be looked into.
When I start the program it is there for a second then disappears.
Many thanks
Richard
Looks to have went down again, will advise Airnav
2E0FLP
Still no 3D, here we go again !!!!
FACTflights
No 3D in Cape Town either.
Thought I had done something stupid again.
John
ZS1AGH
No HF antennae at the moment.
2E0FLP
No John, like yourself, my first reaction when my 3D does not fire up is that I have a problem with my internet connection, causing me some headscratching. So far this has not been the case, always a problem with the Airnav server.
Perhaps the system is being overwhelmed with all the Data being provided to the RadarBox24 site from all the non Radarbox owners:
QuoteDo you have a mode-s receiver and it's not a RadarBox?
Want to share data to RadarBox24.com?
We've started today beta testing of our brand new Data Sharing application.
Apply now and benefit from new features when they become available.
Or is it just coincidence that just after I received this announcement two days ago, problems with the server have arisen again !!!!
Must have to unsubscribe from the announcements, talk about rubbing salt into the wound !!
Paul
The sytem is not being overwhelmed, the network is working fine and has not been down for some time
Its not to do with rb24.com
That has been moved to separate server, there are other changes that happened this week that have caused some issues. Its being worked on again and we hope to have news soon, apologise for the issues caused.
This problem with 3D has reappeared today and we are checking it. Will give an update as soona s it is corrected.
