New Navdata.db3 - 20130422
Started by orkney, April 22, 2013, 03:06:04 PM
No the Navdata updates overwrite not sequentially update,.
I presume you used Windows search to look for all instances of NavData.db3 as to get 88*** you must be looking at the wrong one as if you were looking at the one you downloaded and installed you would have 196*** and the date would be the date downloadedand installed which will be different to the other one.
Within the same data folder you will also have other Navdata** files in addition to NavData.db3. You will have NavData.db3.bak  Navdata.db3 journal  NavData.db3.stmtjnl and navdata-backup.db3
Sketco
Thanks Alan,
Yes, I did the search as you suggested and all roads lead below:
In c:\Program Files\AirNav Systems\Radarbox\Data I have:
Mylog.db3
NavData.db3
navdata-backup.db3
In C:\Program Files\AirNav Systems\AirNav RadarBox 2009\Data I have:
MyLog.db3
MyLog.db3.bak
NavData.db3
NavData.db3.bak
navdata-backup.db3
In C:\Program Files\AirNav Systems\AirNav RadarBox 2009 I have:
Airnav Radarbox 2010 manual.pdf
Airnav Radarbox 2009 manual.pdf
ANRB.elf
ANRB_old.elf
ANRB ( exe file that then launches 3.13)
anrb.chw
While hunting down all these files, I tried to examine the contents using NavData.db3 Tool.
attempting to load either of the NavData.db3 files returns this:
C:\Program Files\Airnav Systems\ AirNav RadarBox 2009 (*also just straight ANRB folder data file)\Data\actype.xlsx (Access is denied) followed by a bunch of Java operations with a good bunch of (unknown source) suffixes.
Is it possible that I just simply corrupted my update in the download??
your thoughts before i download again.
cheers
As the Navdata in V3.13 is an older version I would try moving the Navdata.db3 in C:\Program Files\AirNav Systems\AirNav RadarBox 2009\Data into c:\Program Files\AirNav Systems\Radarbox\Data replacing the one that is in there and then start up again and see what happens.
If it were my set up I would delete everything and re-install V3.13 into C\Airnav avoiding the windows virtual store which can give problems but maybe thats for another day especially if you were not having any problems anyway.
Sketco
Thanks Alan,
No harm in doing a drag and drop across, so i'll try that tomorrow as I have already done an instal from the updater to that directory with no joy, I don't hold out much hope.
Thank you for your time.
As you say, it currently isn't broke, just in need of an update, so i'm a bit leary to poke it with a stick while it's happy enough.
The correct Navdata.db3 file will be around 51,371KB in size
jaskel
There will hopefully be a new update later today.
