D008.dat update
Started by Runway 31, May 14, 2013, 06:03:39 PM
It was brought to my attention that the D008.dat file we are using in now out of date meaning some flags havent been showing.
Please find attached an updated file which will hopefully see the flags showing as required.  I have been running it all afternoon  and havent found any problems with it but if see any let me know and I will correct.
Just replace your existing one with this one and I would suggest that you close down before hand.  The file is located in your data folder.
vonsmalhausen
many thanks for this update Alan,
one thing does trouble me : "old" file = 97,5 kb, "new" one is only 28,9 kb ; seems a BIG difference to me,
i'll install the new file, but shure will make a backup of the "good old one" , ..... just in case ;-)
#3
Many thanks, Alan.
The updated file is now in the flags zip available on my downloads page here: www.rodbearden.com/RadarBox/Downloads.htm
BTW - the old D008.dat file is the same size as the new one, give or take the odd few bytes - I wonder what happened to your old one, vonsmalhausen.
vonsmalhausen
i've no idee wat happened to that file, but i rechecked the size of the "old" one, and it does say : 97,5kb
used the new file, and all is well :-)
jgrloit
Montenegro line in file is missing the first field,
reads:-
Montenegro,01010001011000----------
John
Based in Hexham - Tyne Valley
Yes it is corrected on the update I am working on.  It should read MP,Montenegro,01010001011000----------
I wont answer the other thread
flygfantast
The following should be added also:
SW,Sweden Mil_102005,010010101000001000101010
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks Niklas, got it in
Alan,
Before updating, is the Union Jack what I would call the 'faded' version or the 'distinct' better version ?
#10
Hi Ian,
I have just about finished the dat file and testing it to make sure all is well and am just starting to look at the flags.  I will make sure that its is the more colourful UK flag that is in the file.  Rod has made me 3 or 4 new flogs for inclusion in the update.
Thanks Alan,
I remember having to upgrade to the better flag before. The faded one looks like it's been in the wash too long !
I see the SBS1 community created a new country.dat file on 15 January.  If it helps, I can put this through my normal spreadsheet procedure and generate a new up-to-date D008 file this morning.
Hi Tarbat,
I have a new one on test at this time but many thanks for the offer.  Hope to have it posted later today along with a new flag file.
#14
Okay Alan, I've done the work to create a new one if you want to use it (attached).  Adds 100 new entries, now 774 entries.  Also includes new flags for:
    UK
    Turkmenistan_Mil
    Nigeria_Mil
    Malta_Mil
    Indonesia_Mil
    GE (Guernsey)
So make sure you include all the new entries.  The SBS1 community are very good at keeping this up-to-date, and in the past we've just replicated what they produce to generate a new D008.dat file.  If we're going to diverge from the SBS1 version, then someone will need capture any changes needed and keep this up-to-date going forward.
