Wishlist for V1.7
Started by EINN-07, April 09, 2008, 11:46:54 PM
EINN-07
Thinking ahead for the next version after 1.6 !!
The current outlines are all held in one folder and don't allow for selectively switching off individual items. For example I have an outline for the STARs for Rwy 06 in Shannon and another outline for the STARs for rwy 24. Depending on the runway in use it would be nice to be able to switch off the outline for the relevant STARs not in use.
At present I move the outline for the STAR not in use out of the Outline folder which could be a pain for airports where runways are swopped by the clock on a daily basis as opposed to the weather as happens here.
Something like layers in Photoshop or AutoCad is essentially what's required.
As a btw, I have noticed in V1.5 that the default map setting gets saved to the current screen view after you move outlines in and out of the Outline folder
asecna
#1
I really would appreciate
a fast forward function when playing a recorded file.
then could it be possible to change the name "Home" on the default map to something personal like "baobab1"?
and finally could the recorder close the logfile periodically so that even if the radarbox hangs you do not lose the whole recording.
